Results 1 to 11 of 11
Thread: kx cylinder questions...
    Oct 2005
    saratoga, ny
    2,819
    i have an 84 kx cylinder i just recently got, and have a few questions...
    first off, arent the 83-84 kx cylinders nikasiled? this one isnt, it is cross hatch honed, and it does not look to have a sleeve in it. now is it possible to have the cylinder repaired and re nicked? or should i just get a sleeve and have it sleeved? also the exhaust port bridge has a tiny tiny tiny hair line crack, very small almost un noticeable. is this something that can be fixxed as well, and what would happen if i wasnt to do anything about it? i am trying to get some pics, but my camera is sucking when i try to get a nice close up.
    Nov 2006
    southern oregon
    2,338
    I would sleeve it. I wouldnt run it with a cracked bridge. Maybe have it repaired while away for sleeving.
    2-stroke lover
    Oct 2005
    saratoga, ny
    2,819
    thats what i was thinking, just wasnt sure.
    Newfoundland
    5,280
    I'd get in touch with Corey Sprock and have his Nic guy do the bridge repair and re-Nikisel the cylinder for you.
    Jul 2006
    galway ny.
    534
    that sounds like the thing to do scoot, get it done right then you stop guessing.
    85 tecate 86lt250r
    85atc 200x
    Sep 2006
    Northwest Indiana
    1,893
    Call US CHROME. ( 1-920-922-5066) They can repair just about anything thats wrong with a cylinder. I have 3 kx cylinders and they are all a bit diffrent in the bridge area. What you are seeing is the parting line when the cylinder was cast in the sand mold. Some lines are more pronounced than others. And t-3 lopes has one that looks as though its almost completely saparated. It's been this way since it was new, but looks sketchy to say the least. It definately needs some sort of correction work done in that area. Especially when you consider that this area of the cylinder runs the hottest and the bridge is a small line of metal in constant contact with fire! It will expand at a faster rate than any other part of the cylinder and can cause the piston to sieze and or scuff. Especially when there are basically two halves of the bridge due to poor casting techinques. And remember to always drill 2-3 small holes in the piston where it passes over the bridge to allow oil to get between the piston and cylinder to reduce the risk of siesure. This is a trick that all liquid R models have used forever. They to have a bridge that expands and changes tolerence in that area. But ive never seen them have as poor as castings. And do the right thing and have it re-nicked if at all possible. Good luck
    Oct 2005
    saratoga, ny
    2,819
    sounds good guys, thanks for the info. hey big green, do you know if coery sprock does any bottom rebuilds as well? gonna need a new crank and rod in this motor as well, andi'm not the best at cracking open a bottom end. any help is appreciated. i have a guy by me that might be able to do it, but i am kinda weery about using him cuz he screwed up a friends clutch.
    Jul 2006
    galway ny.
    534
    try best friend ying yang''?
    85 tecate 86lt250r
    85atc 200x
    Newfoundland
    5,280
    Call CWR at 717 837 1907, ask for Greg and ask him about a T3 bottom end rebuild.
    Thats who does all Sprocks motor work/rebuilds now. I had them port a T3 cylinder and just got a set of brake rotors from him. Great guy.
    Sep 2005
    Missouri
    469
    I still build some engines, but mostly projects that spark my interests...Greg @CWR sells my engine kits and assembles them for his customers, but I still build my own. I would send your bottomend to Greg @ CWR.
    Oct 2005
    saratoga, ny
    2,819
    cool thanks for the heads up tri tecate 350
