Results 1 to 8 of 8
Thread: Eastwood Diamond Coat on 350X axle
    Jul 2002
    El Paso, Texas
    512
    I need some advice... I took my new stock 350X axle and polished it (dremeled the sprocket hub, but left it "rough"). I left the protective coating inside where the axle sits in the carrier and on the splines -- so basically all exposed areas of the axle are polished.
    How should I treat the axle to prevent corrosion? I've used the Eastwood Diamond Clear Coat in the past, but have not tested it on a ridden bike....is it good? I thought about a clear powder coat, but I understand it is pretty difficult to remove the sprocket hub...correct? What if I just leave it polished and keep up with cleaning it? Help!
    Thanks!
    Honda
    86 350X - Full Restomod
    85 250R - Legend
    85 Big Red - Clean Original
    85 Big Red - Custom
    Not Honda
    85 Yam Badger 80 - Kids
    99 Pol Sport 400 - Got it FREE
    Nov 2006
    Kent,Ohio
    13
    You might want to give this a try as I am doing the same thing except with my 250r axle. I haven't actually ordered some of this yet but it look like it may do the trick, see what you think.
    Like many other coatings, GLISTEN PC is a MOISTURE-CURED coating, which means it is strengthened by exposure to moisture. It will never crack, chip, peel, or yellow, and is very flexible as well.
    IDEAL USES: As a protective coating on aluminum wheels, chrome bumpers, marine railings, chrome or aluminum covers, grills, handles, ornaments, lights, etc
    http://www.imperialrestoration.com/p...php?category=2
    Jul 2006
    hang it up about taking the sprocket hub off, they are put on under serious pressure and heat at the factory, you wil have to do the axle and hub at the same time.
    Jul 2002
    El Paso, Texas
    512
    Looks good to me, but I have the stuff below on hand. My only worry is that it might not stand up to the abuse that an axle gets. Anyone have experience with it?
    Eastwood Diamond Clear Metal Aerosol 12 oz
    Protect metal parts with a crystal clear, tough, flexible coating that keeps brass, aluminum, steel, die-cast, even cast iron looking great. This self-leveling formulation, resists chips, cracks, fading and yellowing. May slightly dull reflectivity. Resists fuels and temps up to 300ºF. Ideal in underhood applications except exhaust manifolds. Great for polished wheels, aluminum valve covers as well as items around the shop and home. Diamond Clear for Bare Metal is a solvent-based clear in a 12 oz aerosol can.
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    Jul 2002
    El Paso, Texas
    512
    That's what I heard about the sprocket hubs.....so that means I can't powdercoat due to the rubber bushings fitted into the hub's bolt holes.
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Do it right,Powder coat it.
    Nov 2006
    Kent,Ohio
    13
    Quote Originally Posted by 350Kris
    might want to give your stuff a try then. I like to keep the original shine though, thats just me and your spray says may slightly dull reflectivity of the surface, but hey if it works for ya then fine, I'd try it.
    I've worked with the Por15 coats on my showcar and it is really a stuff coating, not even a can chip it! but it is a little expensive...good luck and let me what you come up with.
    Jul 2002
    El Paso, Texas
    512
    The Por15 sounds like a better product to me. It would probably stand up well against the rigors of trail riding. I don't want to have to "redo" the axle in the near future and I plan to ride the bike a lot once it's done. I appreciate the feedback.
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
