I'd like to know what anyone has done to bring the fenders back to life. Mine are good, Just got sun faded over the years. Thanx Dan
'02 ranxher 4x4 '83 big red '84 110, '86trx70 project, '85 bigred project
take a knife hold it straight up and down with the sharp blade to the plastics and scrap it. makes mine look good.
finding a good bike is like finding a good woman, it might or might not happen so hang in there.
Um, i dont know about that :? but I heard wet sanding works great. I plan on trying that in a few days.
I used steel wool on mine then I sanded them with sand paper I started at 400 and went up to 600 grit. It made them look great, if you go on up to 1000-1500 grit paper they would look better than new. Josh
I had the RIGHT to remain silent, I didn't have the ability!
smokinwrench is right, that is what i do to mine, start at 400 then go to 600
1986 Honda 250SX
try paintin them in linseed oil with a brush then get a rag and sprad it tround and rub it in, then set them in the shade to dry a few days, the inseed wil be a little sticky after the few days but not enought to annoy you, works great, my little test, any way good luck.
matt
Paint them;I'm sure there is paint that will stick to plastic available.
1998 Yamaha Blaster;Wiseco and DG equiped(For sale).
1993 Yamaha Timberwolf.
1985 Honda ATC250ES(for sale).
1985 Yamaha Badger.
Jugernaut your right there is a paint for plastic. Go to www.krylon.com and check out their product called FUSION. It is a newer paint for plastics. Or you can try this site which has various products to make paint stick to plastics. Hopefully this helped.
http://www.urethanesupply.com/storeadhesion.html
One word RENEW! This is the best product in the world for renewing plastic of any color, It will make your plastics look beter than you could have ever imagened. Take my word for it buy it now. Call Mountain ATV or visit thier web site at www.mountainatv.com
P.S. if any of you guys try this product I would like to hear your responses.
I was totaly blown away.
I've got some plastic renew that Im' working on my 350x fenders with right now. I can see it helping alot, but I think the key is to really sand it good and I can see already that it's going to take quite a bit of time, and some of the really deep scratches probably won't ever come out. I am working up from 220, to 400 prob and then might do a bit at 600.
73 cr250m elsinore, 85 atc70, 85 250r flattracker, 87 250es bigred, 86 tecate, 2004 gas gas de300
I have done a few and depending on how bad yours is the sanding sugestion works great. I took steel wool and rubbed them down good. This pulls all the white faded areas off. It come of like a powder. then I wet sanded with 400, 600 then 1000 grit. after i hit it with a buffing wheel with some fine rubbing compound and finnished it with 3M marine wax. They came out really nice. the following is a pic of my 200s. It was pretty bad and faded. It had some bad scratches too but they came out with sanding. I have never used Renew but i have heard it works great too.
2003 Rancher 4x4 ES
2004 Recon ES
1985 Honda ATC 70 x2
1985 200s original owner - mint
1985 350x second owner - sweet
1986 350x Good clean rider
1985 350x Good clean rider
1984 125m Absolutley unrestored mint
Thanx I believe ya got me one the right track. I'll let post the results tonite.
I have never used the renew but heard it works great. U used the sanding method ( takes a lot of time to get the scratches out) and worked my way up to 600 grit. It left the plastic looking a little faded, almost white. Then I used a heat gun to heat up the plastic and the original color shines through. That is a great tip that someone put on the board a couple of months ago. You have to be carefull not to overheat the plastic, but using the heatgun you can restore factory color in just a little while.
