Just got my 200x project finally back together. But I am having a heck of a time with the carb. These are new to me, as when I was a kid and these were new old mom and dad would not let me have one, so I could use a little advice. Here is what I have done to the engine. .030 over Pro-x piston. Head ported, race springs. New bigger cam(.340 lift, 266 duration). UNI air filter, and left air box lid off. Cobra exhaust. Carb needle in third notch, and 112 main jet.
I have spent over 8 hours doinking with the carb to no avail. I finally have it just about idling but it will die sometimes. I have the idle mixture screw almost all the way in. Which way makes it leaner in or out? The manual dose not say, and as mine seems rich no mater were it is. It was idling real fast and then would drop down till it dies but I seem to have that gone now. Now it stumbles pretty bad when you give it gas when in gear from a idle coast. I cant seem to get rid of it. I know it needs a bigger main as it is popping at full throttle. I have some coming. But the idle and stumble I just cant seem to figure out. I have had the carb apart twice checking it and nothing is clogged. I have double checked the cam and ignition timing, both are right on. Any ideas?? I am stumped. The cam should not affect the idle as it is not that big. Hay any one in the Batavia- Cincinnati, OH area? Ill pay for a little carb help!!!! LOL Thanks for any help!
