Results 1 to 11 of 11
Thread: tri-z shock fix?
    dancole33 Guest
    Question tri-z shock fix?
    I'm looking to get a better rear shock for my tri-z. The ones I have are blown and don't want to come apart, also the shafts are junk.
    center valley pa
    60
    rear z shock
    i had the same problem the rear shock off a yamaha warrior fits great the only differance was the gas res was a little smaller but its a easy fix
    dancole33 Guest
    Did you change the gas res or just modify the mnt?
    mnnmaz is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2006
    Arizona (USA)
    222
    stay with the warrior shock i put a raptor and its way to tall....
    Original 85 TriZ owner
    Certified NASA welder PM me if you need any welding I do extended swingarms and everything you can dream of
    Three is Always better then four, unless its with women then four is better then three
    Aug 2002
    NY
    2,652
    i found the warrior shock made the bike sit low. i run a banshee shock. i also donr have the gas tank there anymore too so you dont have to worry about hitting that.
    Watertown, New York 13601
    3,382
    The warrior shock i put on my z made it sit the same height or maybe just a tad higher.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    center valley pa
    60
    Quote Originally Posted by dancole33
    i just mod the mount it is a little smaller so i slotted the lower bracket so the hose went in it then bent it back and just made a half moon shim so the factory rubber strap held it in place works great sit about maybe an inch higher (but i am a big guy so it works great) and handel great also . the local dealership said they could send the old one out and get it rebuild for 550.00 but that was a little more then i wanted to spend. this worked great and good luck. a remember when your done n there will be no more later greg
    Ontario, CANADA
    4,538
    Id reccomend searching ebay and waiting for a deal on a works for a warrior, or a shee witha remote resi so it clears the tank. I got one for 50 bucks BIN,
    warrior shock is no improvement, just another shock. Same ride height for me.
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Aug 2002
    NY
    2,652
    i dont know why but it sat lower on me??? once i put the banshee shock on it sat an inch or so higher. which was nice with the +2 westcoast swingarm. best bet is get what every you can find.
    Feb 2006
    AZ
    1,358
    I put a warrior shock on both my Tri-Zs. Seemed to have same ride height as the tri-z shock from what I remember.
    I just blew out my warrior shock replacement this weekend, so don't expect them to last too long. Direct replacement though, so its real easy to replace.
    Hey another new hampshirite. A few of us go riding in NH every so often with all 250 2 strokes. Usually in the summer - if your interested -
    get that bike fixed.
    '86 Tecate
    '85 ATC 250R
    '85 Tri-Z
    '87 ATC 200x
    '85 ATC 250R - Rider
    '86 Tecate - Rider
    Rittman, Ohio
    6,276
    Stock Warrior and Banshee shock are the same length. Stock TriZ shock was about 1/16" longer. Warrior shock is simplest replacement. It is not an upgrade, but its the cheapest and easiest to find replacement. Since yours is blown, I guess you would call it an upgrade in your case!
