no do not twist it, it should slide right down with a little effort and yo have it all lubed up nicey nice. and yes, make sure you have the rings set on the pins correctly. also, i just took apart an 85 motor with a kx cylinder on it, it had that same ring you were talking about, with the little lip, the top ring. but my kxt cylinder and piston did not have that type of ring. maybe its the difference between a kx piston and kxt piston.
