Thread: Tecate 500 engine swap
    RamsesRibb's Avatar
    RamsesRibb is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Louisiana
    316
    When swapping an 86 Tecate, does the KX 500 engine bolt in or does the frame require cutting. I've already guessed about the pipe. Does the swap dramatically increase vibration?
    Previously known as HighFlying101 since 2003
    I changed my email and lost my password
    Current: '85 Tri-Z , '83 250r , '86 Tecate, '80 ATC110
    Prior: '85 FTZ ATC350X, '85 Tri-Z, '85 ATC200X w/ Bassani exhaust, '83 Big Red, '81 ATC185S, '79 ATC110
    http://www.ipetitions.com/petition/tpctrikes/
    Newfoundland
    5,280
    The frame above the spark plug needs to be notched, thats about it. The pipe fits fine. I think custom motor mounts are needed.
    Nov 2002
    Chezzetcook Nova Scotia
    1,837
    How is yous comming bg?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Newfoundland
    5,280
    stockpiling parts man, searching for a KX frame.
