neither you take off that oring on the right of the locknut and then them nuts will slide off then you can hit the axle out to the left
'86 200x
oops i meen snap ring not o-ring get a set of needle nosed pliers in there and pull it apart they are a mofo to get off though
'86 200x
Originally Posted by cragster
I do not see a snap ring. This is a 86 model, not sure if that makes a difference.
they are left handed threads... just to tell ya....
Yep thats where it should be ... just pry it out of there, and then everything else is pretty much self explanitory.
1983 250r
1986 200x
1985 250sx
Yeah that one is reverse threaded i think. Once you untighten them to the left enough, the snap ring should be exposed. Then you can just pop it out with some pliers. The rest of it should be loose enough to remove and slide off the axle by then.
1986 200x- old school D.I.D wheels, Gold D.I.D X-Ring Chain, Rad MFG. Carrier, PRM Grab Bar, Pro Circuit T-4 custom, Maier plastics, 85x forks, 18x10.5x8 kenda klaw mxr's on itp steels, the money pit never ends![]()
Thanks! I knew they where threaded opposite, but I cannot get the big one to budge. I will keep working on it. Its making me feel like a big pussy. LOL!
I have used a pipe wrench w/ 3' bar on the end to move those nuts. They can be really hard to remove, heat it up with a Mapp gas torch, it should be somewhat easier to get off.
id use a 15" cresent wrench and a pipe, over a pipe wrench. Heat it up with mapp or carefully with oxy acetilene (spelling is way off). Then wrench on er
1985 Honda 250es "Big Red" 1984 Honda 200s (Sold)
1984 Honda 125m 1986 Honda 200x (new project)
2003 Raptor 660 1978 Suzuki GS1000
I do not have a torch and I have now bent both pairs of channel locks. I will have to go get a new wrench tomorrow. Thanks again for the suggestions.
get a pipe wrench fitting its size, its far stronger than any channel locks.
definitely gotta get a pipe wrench and a pipe.. i used a 3-1/2 foot custom made pipe wrench to get mine off and tighten them back up...
