Results 1 to 7 of 7
Thread: Tri-Z jetting help
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    Tri-Z jetting help
    Ok, so as you guys may know i recently picked up an 85 Tri-Z. Mods include: DG pipe and silencer, v force reed cage and spacer, K&N filter, and has 215 psi of compression. It has a stock carb, and im wondering if anyone could give me a good baseline for the jetting. Im familiar with jetting in general, but have no experience with the Tri Z or Mikuni carbs- thanks in advance guys
    Oregon
    2,471
    Stock Main Jet is 470 for the '85 , Try 490 do a plug chop ... go from their
    What main jet does it have at this time ?
    wanta86r's Avatar
    Nov 2004
    mn
    385
    it has a 480 in it but a 40 pilot instead of the stock 45. any idea where to start on the needle position?
    wanta86r's Avatar
    Nov 2004
    mn
    385
    help me out guys...please
    Oregon
    2,471
    Thumbs up
    For the Needle Put in the 3 Grove which is in the Middle ...
    If you do a Search On ( Jetting ) you get lot's of info .
    That's why you have not gotten any REPLY's ( it's been covered ) their's a sticky on Jetting also .
    Rittman, Ohio
    6,276
    Quote Originally Posted by ceaserthethird
    What he said.
    Knowing your gas/oil mix would help, but its been my experience that with your current setup, its highly unlikely youll end up above stock jetting, and more likley youll end up lower than stock.
    wanta86r's Avatar
    Nov 2004
    mn
    385
    Ill be running castor 927 at 32:1 with 110 octane gas. So do you think i should go back to the stock 45 pilot jet? I also found that i must have an aftermarket needle, would it be better to get a stock needle and go from there?
