I`ve just got hold of a 85 tri-z and just got it running which is fine til i try and move it, if i stick it in gear i`ve got to give it almost full revs and work the clutch to try and pull away otherwise it dies.
it was gradually gettin there (starting to pull a bit better and pick up speed) and then i switched it off tried to restart it and it backfired then ran crap so i changed the plug it was fine for about a minute then same again only there was oil round the plug around the head mind you i only hand tightened the plug and came back out about 2mm but why the oil?
does it need rings? is the carb needing cleaned? or is it something more sinister?
