Results 1 to 9 of 9
Thread: 86' 350x Calipers: wrong lube or replace em'?
    Dec 2006
    Connecticut
    4
    I am having major problems with both brake calipers on my X sticking, I have cleaned and lubed the slides but they still seem to stick, although they do seem to release after a few minuets. What kind of lube is recommended for the slides and do any other calipers cross over to these bikes.
    86' ATC 350X
    06' KFX 400
    00' Cagiva Gran Canyon
    May 2005
    Hobart, Oklahoma
    570
    I think the rear 400ex switches over, but you can still buy new 350x ones off of ebay or from service honda.
    When I redid my rear caliper, I just used ordinary automotive lube to help get the slide back in. The caliper works great, and I haven't had any problems with it.
    Good luck, and to the forums.
    tyman's Avatar
    tyman is offline Just Too Addicted Arm chair racerJust too addicted
    Jul 2006
    Bedford, Pennsylvania
    458
    wether it'll gum up the pads or not, i don't know.. but i used wd-40 for mine.... sprayed em real good.. waited a day or so and then spun the tire in the air and wiped it to get all it off the caliper
    Minnesota
    784
    Did you actually get the slider pins out and freely moving? Another possible cause might be sticking pistons, ordering new o rings for the calipers and cleaning the pistons might help.
    PA
    3,515
    i use coper never seize on my sliders
    but like hrc200x said it sounds like the piston
    WWW.HREATV.COM
    Apr 2006
    Crestview, Florida
    2,429
    Are you sure its not the master sticking in. Ive had two masters in two months do the same thing, the seals inside had swollen.
    Old 179's Avatar
    Old 179 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Southwest Indiana
    300
    should use silicon grease on the socket bolt and the pin on the caliper bracket.
    Dec 2006
    Connecticut
    4
    Good info...I have had problems with the rear for a while and the front just started. I guess I'll just break em' down on the bench and start again, paying attention to the pistons as well. As far as the master sticking, what do you mean?
    86' ATC 350X
    06' KFX 400
    dufrain's Avatar
    dufrain is offline At The Back Of The Pack Arm chair racerFirst time rider
    KY
    239
    Supposed to use silicone grease like 179 said because petroleum grease can work on any rubber it gets on.Its what Is recommended on car calipers to.
    85-70,79-110,79-110,80-110,86-250ES,85 250r,86 350x,82 250r
