Results 1 to 15 of 16
Thread: ytm 200 worn primary clutch ? (pictures)
    Dec 2005
    U.P. of Michigan
    55
    ytm 200k
    hopefully you can see well enough from this picture.
    Is this clutch worn too far (grooves in the clutch housing) these are maybe 1/32"-1/16" deep.
    is this normal??
    sure don't want to have to buy a new one at $150.00 or so.
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    it looks fine check *Edited**Edited* clutch plates ans see if there smooth
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Dec 2005
    U.P. of Michigan
    55
    I was worried about the grooves on the clutch housing, the clymer manual says pretty much if a fingernail can catch the groves to replace the housing.
    the friction plates dont look to bad, how smooth should they be? just so as not to wear unevenly on the housing?
    also the clymer manual shows to measure for wear the teeth of the friction plate, the yamaha manual shows to measure the space on the friction plate between the teeth and the body.... makes no sense.
    should I try to clean up the housing and the plates with some fine sandpaper?
    Dec 2005
    U.P. of Michigan
    55
    some better pictures.
    the thickness of the over all friction material is about a little over 1mm, the tooth is about 1/2mm or so
    the grooves are about 1/32" deep
    Attached Thumbnails Attached Thumbnails brokenscrew 066.jpg   brokenscrew 062.jpg   brokenscrew 067.jpg
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    You should be alright, now what is the problem your having?
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Dec 2005
    U.P. of Michigan
    55
    The trike slips a little at take off , takes a bit to engage.. not to bad, but it does it even when the adjustment is set all the way tight counter clockwise.
    I was going to replace the secondary clutch since most people say the primary almost never goes bad (except the one way, which seems fine) , but since I had it apart I thought I'd check it all, and havent a clue what Im looking for.
    dont know what they look like new.
    Howdy's Avatar
    Celina, Ohio
    10,079
    It is wore pretty good. You can always look for a good / better used one to install. heck, I may even have one in good shape.
    Howdy
    Dec 2005
    U.P. of Michigan
    55
    Thanks guys.. Howdy, send me a message if you locate one in good shape. I'd be interested.
    do you think my problem could be primary clutch , secondary or both?
    Dec 2005
    U.P. of Michigan
    55
    I did some more looking into it , and I see the housing is warped. not oval that I can tell, but wobbling about 1/32".
    the trike had no problem slowing down hill in first gear, the one way bearing seems fine.
    the friction plates are a little glossy at the tooth.
    the trike doesnt slip in higher gears.
    Dec 2005
    Wisconsin
    1,141
    Run it hard for a month. I had a problem with mine for a while, I just keep it adjusted. It seems it has been getting better. now it will bog down before it slips.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    Quote Originally Posted by jagerlager
    If it doesent slip in other gears then that makes me belive that which ever gear it slips in that clutch plates is no good, check into them.
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Willis, TX
    62
    I am having the exact same issues with the exact same bike. Got new ones and now the bike runs fine although we haven't confirmed that the old ones were bad and just needed to be driven a bit (as stated above) Those turds are expensive! Hey just hang in there and play with it, doing the same with mine and getting positive results across the board.
    Dec 2005
    U.P. of Michigan
    55
    removed the secondary clutch for inspection tonight.
    The friction plates measure 2.8-3.0 mm, I think yamaha specs are to replace if less than 2.8mm (what would the measurements of a new one be?)
    The springs measure 36.5 MM I think yamaha specs are if less than 34?
    so apparently they are fine?
    the housing shows a little wear.
    Attached Thumbnails Attached Thumbnails plates 069.jpg   secondary detail071.jpg
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    Hmm if it has grooves they look fine though. Maybe your friction plates are worn, i heard somwhere you can put them on concrete and turn them like back in forth to score them up so they catch, not sure though.
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Willis, TX
    62
    Are you that guy that sold me that used car that kept breaking down?
    JKJKJK
    That is actually a pretty decent idea, if mine is worn I'll try that and report back. It will be a while though : (
    On a better note, I just traded my 88 yfm225 moto4 for a running Ford f250 diesel supercab with a 6.9 liter in it. Pretty swizzle deal.
