I just replaced the crank seals in the 85 Z. I put it all back together and the kick starter seemed to be stuck...so i just took the clutch cover off tonight and i pulled everythjign apart i thought it was the kick mechanism because it had given me trouble before. Looked fine,
So i pulled out the spark plug, put a wrench on the primary drive gear to see if i could rotate the motor, and it wont budge?
Before the crank seals it would turn over fine.. is there some way they could be compressing the crank bearings? I tapped them in with a large socket, but only far enough that they seated.
WHATS GOING ON!!![]()
I do extended swingarms and everything you can dream of
