Results 1 to 10 of 10
Thread: problem with trike
    Punxsutawney Pennsylvania
    8
    Question problem with trike
    i have a 82 honda atc 200 when i will choke the carb it will shoot a stream of gas out of the carb and it will start running out of the two little vent things in the front of the carb and it will run out of the overflow hose the bike has been sitting for a while so i cleaned out the tank and got a bunch of junk out from that and after i did that it still flooded and shot fuel out the vents inside the carb anything will help
    Sep 2006
    NEWFOUNDLAND
    53
    180 degrees off timing i am thinkin.. give her a pluck and have your hand over the carb if it blows out its off timing if it suckes in your ok
    dufrain's Avatar
    dufrain is offline At The Back Of The Pack Arm chair racerFirst time rider
    KY
    239
    Did you clean out the carb bowl and jets
    85-70,79-110,79-110,80-110,86-250ES,85 250r,86 350x,82 250r
    hey, check the valve lash, sounds like the intake valve isn't closing all the way.
    one cylinder is not enough!!
    8
    Smile
    yes i did clean the floats and that but what is weird is that it will run sometimes if you give it a squirt of ether and it will run good but then if you shut it off it wont restart
    smyers33 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Tennessee
    416
    Make sure it is getting air, gas, and spark. So clean the airfilter, make sure the petcock isn't clogged, and get a new plug.
    1983 250r
    1986 200x
    1985 250sx
    leroy, new york
    1,025
    it sounds like its flooding itself
    St Helens, OR
    611
    Quote Originally Posted by 4cylinders
    yes!
    i cant believe someone would actually say "its 180 off"
    since when do thse motors magically get themselves 180 off by sitting for a while
    Dec 2006
    ofallon mo
    103
    sounds like the little thingie under the float that stops the flow of gas either isnt sealing or is getting stuck halfway make sure u put the pin back in the float and it didnt come half way out
    1985 honda 350x
    8
    on my 82 200 what should be the valve specs for the exhaust and the intake and i found the intake is too tight so i want to readjust them thanks
