Thread: Tri-z axle
    Scotland
    47
    Tri-z axle
    would i be right in thinking that the axle and axle carrier from either a blaster or a banshee will fit the tri-z?
    oh yeah and the sprocket hub? mine is in bad shape, there is far too much play between the sprocket hub and axle.
    Front royal, va
    2,186
    both the banshee and blaster axles fit, not the carriers, and the banshee sprocket hub works perfect!
    Banshee is a better up grade sprocket hub!!!!!
    Rittman, Ohio
    6,276
    Banshee axle and TriZ is the same. Blaster axle may fit, but Im pretty sure its shorter. Bansee and Blaster sprocket hub both fit. TriZ carrier is unique.
    Scotland
    47
    sound thanks for the info now i can look out for a good used 1 over here when the money starts coming in again.
