I finally got around to putting this carb on my pretty much stock (K&N filter) '85 250R today. I had called Carb Parts and they said I should use a 158 main and a 50 pilot, air screw one turn out. Got it all together and it started ok, turned the choke off and it died.
Now the question I have is does the air/fuel mixture screw affect anything other than the idle. I have it a 1/4 turn out and it idles ok, idles even better with it in all the way. I know the pilot jet is too small but it would suck to have to change it. Will it hurt anything with the screw set like it is?
Also along the same lines, when I rev it up and it is idleing back down, it doesn't come down smooth, it kinda steps down for lack of a better phrase. Can anyone smell what I'm stepping in?
