Results 1 to 6 of 6
Thread: PJ 36 on an '85 250R question
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    I finally got around to putting this carb on my pretty much stock (K&N filter) '85 250R today. I had called Carb Parts and they said I should use a 158 main and a 50 pilot, air screw one turn out. Got it all together and it started ok, turned the choke off and it died.
    Now the question I have is does the air/fuel mixture screw affect anything other than the idle. I have it a 1/4 turn out and it idles ok, idles even better with it in all the way. I know the pilot jet is too small but it would suck to have to change it. Will it hurt anything with the screw set like it is?
    Also along the same lines, when I rev it up and it is idleing back down, it doesn't come down smooth, it kinda steps down for lack of a better phrase. Can anyone smell what I'm stepping in?
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Sabula,IA
    620
    I think you should go up on your pilot first. I've got more mods than you and I use a 62 pilot. From my experience, the air screw usually goes best at around 2 turns out. The idle doesn't come back down smoothly because it's too lean.
    Clarks Summit PA
    1,236
    i agree w the 2 screws idea.. but the 158 main sounds abit much for a stocker.. maybe 154? who knows.. if it runs well w it.. leave it.. what exhaust you have?
    Ride it like you stole it! And never look back! They are too far behind to see!
    Nov 2002
    1,189
    it is probably the pilot. start it on choke, then rev it up a bit, then turn the choke off. it might run rough, but that tells you that your pilot is too small.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    RichinMO's Avatar
    Aug 2002
    Waynesville, MO
    321
    Shoot, didn't want to have to take that thing off again. Thanks guys.
    1985 ATC250ES
    1985 ATC250SX
    1985 ATC70
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    its a two stroke get use to messing with it!!! i have a small screw driver inside my crossbar pad and use quite regularly ,,, tuning is a important part of the life of a two stroke engine ,,,, in two years of riding i have never fouled a plug and my trikes don't grow moss on them either,,,,
