Results 1 to 10 of 10
Thread: 1983 Honda ATC 200 Rear Axel Stuck
    Suffolk, VA
    33
    OK I cannot get the rear axle out. Got drum off but axle will not come out. I want to replace the bearins and seals durng restoration.......HELP
    Also, I have the tip from a tool steel punch stuck in the end of the axle where the castle nut goes. Tried drilling but only broke its. Any idea on removal?
    Attached Thumbnails Attached Thumbnails Right Side Close Up.jpg   Rear Brake Drum.jpg   Rear Axle Right Side.jpg   Axel Close Up.jpg   Right Side Threads.jpg
    Larry
    Suffolk, VA
    1983 ATC 200
    Dec 2005
    South Carolina
    61
    Having the same problem, Restoring a 1981 Honda ATC 200 wanted to start with the chain cover but can't get the inside cover off, just like your pic's look!!!! How did you get the axle off ???? Also I can't even get the brake cover off of mine; no bolts holding the drum cover on like yours so I should just be able to get a screwdriver a pry it off......WRONG!!!!
    leroy, new york
    1,025
    if the bearings are siezed on the axle. u might have disasemble the berings. DO NOT DAMAGE THE TREADS that holds the hub on its a pain for the rest of *Edited**Edited* life.
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Do you have a vise? Put the carrier in the vice verticaly and try pounding it out. But make sure you use a piece of wood so you do not damage the threads on the end. That has worked for me in the past.
    TF 07,08,09,10,11,12,13,14!
    The best investment I ever made was a vertical press. They are as cheap as 150$. Mine was 200$ and it's 20 tons. With that press and heat I can get just about anything apart.
    Dec 2002
    salem, nh
    1,339
    air compressor and air
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Jul 2006
    western ny
    3,366
    i put the nut on the edge of the threads and used a sledge . it came out and the threads were perfect.
    GIT IT RAAAGGGGG !!!!
    Feb 2006
    Central Florida
    1,090
    larry, did you ever get this fixed?
    I fought with axle nuts for a few days and lost. I came back a month later and stuck the whole carrier/axle in a vice - locking onto the outside nut and cranking on the top one....
    - it can be frustrating, be patient and persistent and you will get your results.
    quiet people seem intelligent
    Apr 2005
    Elrod, IN (near Milan)
    114
    I had this same problem
    I threaded the castle nut well back onto the axle threads, stood up a hardwood block, and literally beat the crap out of mine to get it to free up. It probably took 10-12 FULL swings with an 8 lb sledge. With the nut threaded well onto the axle, the worst damage you'll do is possibly damage the nut a bit, but who cares, the axle will be free. Stay with it, eventually it will have to give way. You just can't be afraid to swing that sledge!
    I'M GETTING TOO OLD. IT TAKES ME AN HOUR AND A HALF JUST TO WATCH 60 MINUTES.
    '85 Big Red 250es (Beer truck)
    '85 350x
    '85 250r
    '84 ATC70
    '01 Yamaha Warrior 350
    '05 Honda Recon 250
    Always looking for more!!!
    '05, '06, '07 TF survivor. Looking forward to '08!
    Putting the nut on helps, BUT..... You will still end up screwing up the threads. Not everyone has oxy/acet torches but anyone can buy MAPP gas. It burns hotter than propane and if you patiently heat the seized are it will decrease the amount of ruined parts immensely.
    I heat everything that has never been apart before or got allot of water in it and it basically can be removed with a 14oz ball peen .
    Drawbacks? Fire, goodbye zinc coating (usually gone at this point anyhow) and every seal and oring melts. But, none of the important parts get ruined.
