About 2 weeks ago I had my Tecate out at the desert, and the engine started making noise so I finely tore into it and found the problem. The cage on one of the ball bearings fell apart and messed up the water pump gear and another gear.
Does anyone know if this is the same engine they used in the Tecate 4? Because if it is I will have a slightly higher chance of being able to get the gears at my local Kawa shop.
Check out some of the debris I found in the case. I tried to get a good pic of the gears but I couldn't get the camera to focus on them but you can still see the teeth are messed up.
