Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: 400ex axle swap into 250R?
    staceyl200's Avatar
    staceyl200 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2005
    South Wales UK
    253
    I,m going to deviate slightly on this post but will a TRX 450R axle and/or bearing carrier work in an 86 atc 250R because I see quite a few on UK ebay for sale for a few beans ,,and I see not a lot of 250R axles/bearing carriers over here ,, so the 450R,s would be tip top if they fit ,, Has any one got info on this????
    Cheers
    Stacey
    05 TRX 450R HRC (Black)
    86 ATC 250R
    83 ATC 200X
    Maryland
    3,077
    I was also wondering if the 450r axel fit on hte 400ex rear end. the 450r axel is an inch wider!
    Jackson MI
    1,688
    I can tell you a little about the 450r & 250r carriers & axles, as I have a 450r torn to shreads In my barn.
    The 450r sprocket hub Is offset way towards the axle carrier. The carrier Is also narrower In total width. This means the the 450r carrier would not stick out of the swinger far enough to put the brake stay on In a 250r swinger. The outside diameter of the carrier's are the same size & the bearings are also the same Inside diameter. This means the axles are the same outside diameter. A 250r axle wont hit the adjuster side of the carrier on the 450r. The 450r axle hits the adjuster side of the 250r carrier. The brake rotor hub would have alot of spline sticking out where the jam nut & collar goes on, but could probly be made to work with a spacer behind the clip collar. The bearings might not hit the correct spot on the 250r axle on the right side of the 450r carrier also. Wow that Is a mouth full. One cool thing about the 450r carrier Is It has double bearings on the chain side. The brake stay's are the same Inside diameter also & the brake hub spline Is the same.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Aug 2007
    Burlington maine
    652
    Quote Originally Posted by 200x Basket View Post
    and 400ex's have been around for 14 years. what you are saying make NO sense.
    Im not sure what state you are in, But here in ME the EX came out in 99.
    Im not seeing 14 years there. This thread is gold as I will be buying an extended axle for my R, It is easier to find extended EX axles.
    1987 Honda 200X 90% way through frame up.
    1987 CR500R Motor, Soon to be a 540 ATC motor
    1986 250R frame, For now
    2008 Honda 700XX
    2004 KFX700 Torque monster!
    2011 Can-Am Commander 1000X
    Looking for misc Liquid R parts
    Ironbnder's Avatar
    Ironbnder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Alexandria, La
    363
    I appretiated this thread also. With Jasons knowledge and helpfull post, this could qualify for World Class Help. I learned some good stuff here.
    FEEDBACK@ http://www.3wheelerworld.com/showthr...-for-Ironbnder
    86 250R
    86 350X
    87 250sx
    85 200x/cb350 custom
    81 185s/200x/250r custom
    79 atc 70
    Mini-Trail z50, 110cc Pit Bike
    and many multi-wheeled machines
    junit's Avatar
    junit is offline At The Back Of The Pack Arm chair racerFirst time rider
    fremont ohio
    154
    will a 400ex axle fit in an 86 350x
    Sep 2003
    Elizabethtown PA
    1,581
    Quote Originally Posted by junit View Post
    for the 350x's you can use a 250x/300ex axle but you have to use the 300ex wheel hubs. Just like above get a 300ex axle + hubs and reuse everything else.
    I have a lonestar +4 300ex axle in my 86 350x so i know it works.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Baltimore, MD
    6,088
    Jason, does the 300ex axle work in the 85 350x as well? It just uses the stock 350x bearings and no special mods? I may have to do some shopping. LOL
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Sep 2003
    Elizabethtown PA
    1,581
    yes it'll work in a 85 350x also. Go on ebay anbd get a G-force new they are under $200 for a +4.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
