Results 1 to 15 of 21
Thread: how would you go about making a 3 wheel drive big red?
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Missouri
    319
    need some kind of spliter to shoot power up to the front wheels through the top tube some how.
    or maybe it could be done with parts from one of those rokons or whatever they call those tractor tired 2 wheel drive motorcycles?it would have a chain driven front wheel then.
    run a axle through the top tube some how??
    have a CV joint and the head tube?
    with a compact 90* gear box that is also the top triple tree?
    run a drive shaft through one of the fork arms?
    the drive shaft housing would be one of the fork arms and there would be another 90* gearbox down at the wheel hub.
    it would have a air cooled 350 rancher motor in it. and it would be a mudding monster.
    man i would buy one of these if i could.
    Are you kidding? Just buy a 4X4 quad, leave the ATC alone. The only way I can think of would be an output shaft on the motor that drives a cable that drives a ring and pinion to get the front wheel spinning. Sounds like alot of work and a big hassle to me...
    springville, PA
    6,185
    you'd have to covert on of the old 2wd rokon or other 2wd "dirtbikes". Its not worth it though although very cool idea
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    darrel632 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    alberta
    429
    probably the easiest way is to wipe out the rear diff, install a hydrulic pump and tank off the shaft drive and run 3 equal pumps for the wheels, run the motor at a constant velocity, and use a variable valve for fluid drive; it would be slow, but a varitable tank when finished.
    anything with a splitter, and shafts, gear boxes, extra chains would compromise the engine beyond belief, I 'm pretty certain each U-joint is equal to a 5% power loss, gearboxes are about 12% and the chain drive system would have to be pretty unique concidering that you have 3.5 inches of travel in the suspension
    Jul 2006
    http://www.2wd.nl/
    it can be done
    Mar 2005
    Newcastle,Australia
    47
    Bolt another wheel to the outside of one of your back wheels = 3WD
    Bolt one to the otherside as well = 4WD
    Bolt 4 to each side = 10WD
    Where do you stop? The sky's the limit!!!!!
    P.S lol.
    Bretto
    Jul 2006
    http://www.rokon.com/index.htm
    find one of these used and adapt the front design to the red and have a killer machine then!!
    Columbia
    5,131
    Heres an old thread about 3WD. You can pull some info from it.
    http://www.3wheelerworldforums.com/s...ad.php?t=28156
    Nov 2006
    Missouri
    319
    i was not going to make a 3 wheel drive 3 wheeler, but oh my god do i want a rokon now!
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    How about just mounting another motor on the front rack, and running a chain down to drive the wheel.
    Just thinking outside the box.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
    Nov 2006
    Missouri
    319
    that is a frightening vision.
    a chain saw motor mounted to the front rack going full throtle through a mud pit.
    get some!
    ontario canada
    64
    i have seen the motor on the rack deal and i worked. it had a 8 hp honda mixer motor on it and it had a redution gear small gear on the top and a 200m rear gear on the wheele and a gas control on the left side it had e start to but you cant over 2 end gear or you will over power it.i will see if i can get a pic
    Sep 2005
    Saskatchewan(Moose Jaw)
    769
    Quote Originally Posted by ATCnut
    I was thinking about the same thing, but then I thought, Imagine how hard it would be to make your front tire and your rear tires go at the same speed, so I thought if you have an engine on the front and have electric start on it and have it on full throttle, and just before the mudhole you hit the electric start button, then maybe a 7hp snowblower engine kicks in and sends your front tire spinning at 100mph Just a though that someone should try sometime on a trike with a strong front rack.
    Current Rides
    3 skidoo's, 1 quad, and 1 trike
    http://www.cardomain.com/ride/2679723
    Sep 2006
    NEWFOUNDLAND
    53
    sound to me like somebody should b looking for a 250 trx frame and a 300 engine and front differntial
    Nov 2006
    Missouri
    319
    "have an engine on the front and have electric start on it and have it on full throttle, and just before the mudhole you hit the electric start button, then maybe a 7hp snowblower engine kicks in and sends your front tire spinning at 100mph"
    YOU GO FIRST!
