Here is a pretty typical Honda one. Sometimes that plastic filter tube stays stuck in the tank neck where petcock threads on and other times it comes out staying on the petcock itself.
Note also that the oring that goes at very bottom of the filter. You only snug the petcock assembly down because of that oring, no need to crank on it like crazy.
Last time I bought one of those filters they were 13 bucks, so they are not cheap!
The tube has two filters, that is how your reserve works, once gas gets below the top one gas will no longer be delivered till you switch to reserve, then it sucks it through the bottom one!
