Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
Thread: Polaris AWD issue.
    NE Arkansas
    2,344
    Yeah, I know what you mean, but mine would be in AWD full time even with the switch in 2WD mode for weeks at a time, I never needed the AWD. The gear oil I used was way too thick, and like Will stated, when it detected the speed difference in the shafts it would engage to front end to assist. I have it fixed now, I'm glad, hehe.
    My Rags
    Nov 2004
    Atlanta TX 3-states area
    1,592
    The rear end on the 500 i think uses Polaris AGL. The transmission and rear drive are all one unit, then thats what you need to put in it. You can try to drain and fill that front end after a few more days to see if it clears it up completley. It should.
    -Will
    1985 Honda ATC 350X
    2003 Yamaha Banshee
    2003 Polaris Sportsman 500
    There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
    NE Arkansas
    2,344
    In my manual they call for the same fluid front and rear. It having the "Turf" mode and the Versatrac rear may be why. Thanks again!
    My Rags
    NE Arkansas
    2,344
    We got alot of rain yesterday, so I just took the ATP out behind the pond in the mud, I had to "try it out", hehe. That 100% fixed the problem. 2WD when I needed it and AWD when it was supposed to. Thanks again Will! I owe ya one.
    Travis
    My Rags
    Jun 2009
    Louisville, KY
    Exact same AWD problem!?
    Hello. Just joined the forum because I've finally found someone that had the same problem i'm having now!
    Can you help please!?
    Just bought an 03 polaris magnum 4x4 and I love it.
    Got a great deal on it and it was hardly used at all.
    When i have the switch in 2wd and the rear wheels start to spin a little bit, the front wheels will kick in.
    The switch engages and disengages the 4wd instantly just like it should. But in 2wd it will not let the back wheels spin very much with out kicking in the front too.
    The dealership had no answers for me.
    How did you fix yours?!
    NE Arkansas
    2,344
    Holy cow, I can't believe that that was 2 years ago!
    Change your fluids, for sure. That is the easiest thing to try.
    As a rule for Polaris's:
    Front diffs (whether centralized or external)- ATF fluid.
    Rear diffs- 75w90 gear oil.
    That will keep things going the way they should.
    My grandpa's 2000 Xplorer has one of the front hubs that starts sticking every now and then, change the fluid, fixed.
    Keep fresh fluid in it and you should be good. Cheap enough to try.
    My Rags
