Results 1 to 7 of 7
Thread: help with a 225dx
    May 2004
    sanat rosa
    help with a 225dx
    just bought a nice 225 dx, very cool trike, but i bought it not running, got it running but have one problem i think i know the answer, but hoping someone might have another, runs well but idles up and down and spudders throught the carb think it needs valve job and proboly new rings amaybe just a new top end but dont want to tear it apart yet. anyone have and ideas?
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    1. to the board.
    2.Do you have a Manual?
    3.Need
    4.Adjust Valves,if that don't work then is sounds like a Carb problem.
    Mike_Ham_250R's Avatar
    Mike_Ham_250R is offline Even team-red-rider is cooler then me. Arm chair racerJust too addicted
    Pennsylvania
    1,058
    Quote Originally Posted by edog
    1. to the board.
    3.Need
    Sounds like a Carb problem.
    I agree. But if it pours out black smoke it could need a valve adjustment.
    -Mike
    Dec 2005
    Wisconsin
    1,141
    Welcome to the forum.
    Edog has a nice 225. We want pic's for yours!
    My ytm-200 sometimes will cough (backfire) through the carb. I am ignoring it untill this summer when it gets rebuilt.
    I don't know what it is exactly. But I am lead to the valves/ cam/ rockers causing this.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    mark38090's Avatar
    mark38090 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Hawthorne, Florida
    354
    My latest YTM200 does the same... I found the o-ring between the carb and the intake is ripped...
    1984 Honda TRX200
    1985 Yamaha 200ERN ( two of these now)
    1985 Honda 250SX
    1991 Suzuki LT230
    2003 Honda Rancher 350ES
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by mark38090
    You may have marks problem, up & down idle spells air leak because it is getting a unstable or fluxuating fuel mixture and is lean which can be really bad for the motor.
    Run it at idle with the problem acting up, spray WD-40 around all carb areas and cylinder base mating surface area, if the ide steadies out for a split second when spraying, you found the area where problem is.
    This has worked for me a few times and not saying that it IS your problem, just seems like a good possibility though.
    dufrain's Avatar
    dufrain is offline At The Back Of The Pack Arm chair racerFirst time rider
    KY
    239
    The intake manifold is bad alot of times on these things,The rubber seperates from the aluminum.Black smoke usually means too much gas.Clean the carb out good and set the air screw to spec while you are inspecting the intake manifold.Dont forget to clean out the air filter to. When you need rings and a valve job the smoke will be blue and stink like burning oil. Do a compression test will tell
    85-70,79-110,79-110,80-110,86-250ES,85 250r,86 350x,82 250r
