Results 1 to 9 of 9
Thread: YTM aftermarket exhaust
    KC is offline New to the board Arm chair racerNew to the board
    Mar 2003
    Kansas City
    34
    I am in the mood to put an aftermarket exhaust on the old 1984 YTM 200E. Who sells them? Anybody have a few websites that I can browse thru? Do I have to order one for another ATV and fit it on to the YTM? Any imput on tricks or technique for more power out of the old YTM would be great!
    Snohomish, Wa
    1,028
    ytm
    dont think there is any aftermarket exhausts for the ytm's, the Tri-Z is really is the only Yamaha 3 wheeler aftermarkets really touched.
    These trikes have some protinetal. You could almost make a better exhaust by finding a another aftermarket muffler off a similar bike and fabing it on, and then just get a 1/4 inch better pipe, and if you can get to a pip bender then you can custom build one. The exhaust is really choked down. once you open it up then you can have some potinetal.
    other mods, Aftermarket Open airfilter, Bore out the carb, re-jet, Port & Polish the head (which I am under way on working on thoses), Bigger piston.
    I wish there was a company that just focused on 3 wheelers, If I had the cash and knowledge I would do it, but Im working on that.
    Thanks
    Tyler
    85 ATC 250r -Under Construction
    86 TRX250r
    05 KFX400
    02 400EX
    Dec 2005
    Wisconsin
    1,141
    http://denniskirk.com/jsp/product_ca...901&mmyId=6281
    Theres your DG exhaust system.
    http://www.webcamshafts.com/
    Theres your camshaft.
    Put a uni filter on it, rejet and ride it.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Baltimore, MD
    6,088
    I think pro-tec once made goodies for the ytm200. Is the ytm200 engine like the bw200 engine? If so I just recently got an aftermarket exhaust for the bw200 and am now looking for a muffler. Check on ebay. I'm sure there was support from companies like bassini. Post an ad in the classifieds and see what turns up.
    dufrain's Avatar
    dufrain is offline At The Back Of The Pack Arm chair racerFirst time rider
    KY
    239
    Had a buddy that had an aftermarket exhaust that came on his 225dx.It didnt have any label on it but it had a larger headpipe and aluminim muffler.It sounded pretty good.
    85-70,79-110,79-110,80-110,86-250ES,85 250r,86 350x,82 250r
    Nov 2002
    Kirkville, NY
    3,831
    As WIkid pointed out DG still makes a performance pipe for the YTM200's so that would be the easiest to get. At one time cobra and Kerker also made pipes but they have been discontinued.
    As for other mods it depends on how much money you want to put into the trike. You can also get a hi compression piston, port the head, performance cam, different air filter setup, bigger carb. and maybe something else that I am forgetting.
    The BW200 engine is very similar but I don't think the exhausts are the same.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Feb 2007
    Canada
    12
    There are 2 Aftermarket Cobra Pipes for a YTM225 on ebay, but im sure they would fit on a YTM200
    86 Yamaha 225DR - My Baby (Fresh TopEnd)
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Got any pics of your Yami?
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by natedizzle09
    225 and 200 pipes are different.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
