Results 1 to 7 of 7
Thread: 87-89 trx piston 5mm shorter than 86 ATC ???
    Mar 2005
    Newcastle,Australia
    47
    Is this correct?
    Bretto
    USA PENNSYLVANIA
    102
    I think the wrist pin location is 5mm different.The pistons are the same size
    Jun 2003
    englishtown NJ
    2,676
    the pin is 5mm higher on the piston and there is some diference, as 87-89 cylinders had a bridged intake. Both the style pistons will work wtih 85-89 cylinders. If you have a short rod motor, your only choice is a 85/86 piston, long rod: 87-89 piston or 85/86 piston and 5mm spacer plate.
    Jun 2006
    Ohio
    57
    Quote Originally Posted by PWK39
    Yeah, the pin is 5mm higher on the 87-89 piston which requires the long rod 87-89 crank. I wouldn't use the later piston with an 85-86 cylinder though.
    "Everything's a good idea when you're drinkin'"
    "Without rules, we'd all be livin' in trees, flingin' our crap at each other" - a very wise man
    2003 Lonestar 250R
    2001 Lonestar 250R
    1986 TRX250R restored to new
    1986 TRX250R still in pieces
    2007 TRX450R
    2004 TRX450R
    1999 CR250
    1999 CR500
    1996 CR250
    and many more
    GNCC Vet class
    #102 (WTF)
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    The overall piston height is also different. I've got an 85-86 piston next to an 87 right now and the 85 is noticeably higher. Both are wisecos by the way.
    Mar 2005
    Newcastle,Australia
    47
    Thanks for the help guys. Ive got an 86 motor that i've just ordered the a TRX250R 87-89 (5mm longer) Hotrod. So if i've got this right i can use an 86 piston with spacer (already have spacer on hand) and the 87-89 without? my cyclinder has no bridge on the intake.
    Bretto
    Jun 2006
    Ohio
    57
    Quote Originally Posted by BC250R
    That will work fine. The reason that I don't recommend running the newer piston in the 85-86 cylinders is because of the lack of the bridge in them. The 87-89 piston is fully skirted, and since there is no bridge on the older cylinders, there's a chance that the skirt can snag on the intake port on the downward stroke.
    2003 Lonestar 250R
    2001 Lonestar 250R
    2007 TRX450R
    2004 TRX450R
    1999 CR250
    1999 CR500
    1996 CR250
    and many more
    GNCC Vet class
    #102 (WTF)
