Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 61 to 75 of 94
Thread: Pros and Cons of the 185s
  1. #61
    Dec 2006
    Las Vegas, NV
    423
    it is an 83 with upgraded suspension. I got the title with purchase
    85 350X, 85 250R, 99 TRX 90, 05 Predator 90, 05 TRX 400ex, 2019 RZR4 XP100
    FEEDBACK for Vegas250rr
  2. #62
    PA
    3,515
    Quote Originally Posted by atctim
    Hmmmmmmmmmmmmmmmm..Points to ponder.?.?.?.?
    That is a 1983 gas tank, and the 83's had front suspension from the factory. What model year is this machine? Was the suspension upgraded? or is this an 81 or 82 185S with a newer gas tank?
    BTW - nice score. I like you trike!
    the factory didn't have triple clamps on the 185
    WWW.HREATV.COM
  3. #63
    Tionesta, PA
    5,747
    Vegas,
    1983 was the last year for the ATC185S. In 1984 the 200S took it's place. What displacement is stamped onto the side of the engine. If the paperwork says it is a 1985 ATC185S - it is plainy wrong.
  4. #64
    Tionesta, PA
    5,747
    Quote Originally Posted by SWIGIN
    Re-read my post - Either the suspension was upgraded from an 83's existing suspension, or it is an older model with an 83 gas tank and a suspesion kit. Sorry if I did not make that clear.
  5. #65
    Dec 2006
    Las Vegas, NV
    423
    Vegas,
    my bad, I meant 83... I just got in a hurry typing
  6. #66
    Jul 2003
    Las Vegas, NV
    124
    uhh, it's a 83, the forks are after market.
    F.U.2 RACING
    Atc90, bandito frame
    Atc185 x2
    82 250 (300 kit)
    83 250R
    200ES Big red
    Atc200X (with lifan motor)
  7. #67
    Apr 2006
    redding cal.
    i have an 83 with a 200x cylinder,piston,head and a super trapp and that thing probably goes about 50mph. i nead another one!!
  8. #68
    Jun 2004
    Oregon
    1,784
    Quote Originally Posted by random-strike
    my yamahauler goes 90mph and i smoke banshees and ive never been beaten. prove me wrong
    Well, I raced an f-14 on a aircraft carrier once! I topped out around 290 i think..Man i was flyin!
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
  9. #69
    Jun 2004
    Oregon
    1,784
    i have one of the no suspension yamaha 200s they are called yamahaulers.
    that thing will go through and over everything it seems.
    they are fun in their own right
    never seen a 198x yamaha 200s called a yamahauler..Must be a pretty rare bike huh?
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  10. #70
    St Helens, OR
    611
    Quote Originally Posted by Fox250R
    homosexual
    http://www.3wheelerworld.com/1984yamahaspecpage.shtml
    YTM200EL Yamahauler
    Frame number ??
    Engine number ??
    Engine type 4 stroke, Air cooled
    Displacement 196.3 cc
    Bore x Stroke 67 x 55.7 mm
    Compression ratio 8.5 to 1
    Maximum Torque 10.6 ft-lbs @ 6000 rpms
    Compression ??
    Transmission speeds 5 speed
    Clutch Type Automatic
    Oil Capacity 1.6 Qt
    Carburetion Mikuni VM22
    Starting system Electric starter, with recoil backup
    Fuel capacity 2.4 Gal
    Wheelbase 45.3 in.
    Overall Length 73.4 in.
    Overall Width 41.3 in.
    Ground Clearance 5.5 in.
    Seat height 25.8 in.
    Front tire 25 x 12 x 9
    Rear tires 25 x 12 x 9
    Front suspension Telescopic forks
    Rear suspension none
    Front brake Drum
    Rear brake Enclosed Disk
    Final drive Shaft
    Dry weight 322 lbs
    Approx. retail new $1,729.00
  11. #71
    Jun 2004
    Oregon
    1,784
    homosexual
    YTM200EL Yamahauler
    Frame number ??
    Engine number ??
    Compression ??
    Oil Capacity 1.6 Qt
    Wheelbase 45.3 in.
    Front brake Drum
    Final drive Shaft
    Dry weight 322 lbs
    Dont see a 200s...LOL!
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  12. #72
    Dec 2006
    Las Vegas, NV
    423
    enough is enough guys, fight like girls in the PMS, not in threads designed to inform and enlighten
  13. #73
    St Helens, OR
    611
    not 200s
    200s as in plural, there are more than one 200cc non rear suspension yamahas
    reading comprehension > you
  14. #74
    Jun 2004
    Oregon
    1,784
    not 200s
    This coming from someone who doesnt wear a helmet
    punctuation marks > YOU! 200's
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
  15. #75
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Ditto on that
    TF 07,08,09,10,11,12,13,14!
