ok i recently bought a used 350x motor. when i bought it we had to switch the stator from my old bike and the kicker shaft over when we had the cases open every thing looked super clean like the motor only had a couple of hrs on it if that. now the problem is after i installed every thing it dosent want to start. so after about an hour of kicking it i decided to pull start it so we did and it started and it runs smooth has pretty good throttle response but if u dont keep fethering the throttle itll die so i took the carb off and looked at the float and its moving freely but i have a leak coming from the carb some where like the over flow tube and its squirting gas out towards the airbox any insight might help
the motor has plenty of compression
