Here is some pics of the cooler in stalled.. The cooler is a NOS Lockhart 1975 KZ650 my buddy had sitting in his garage... I drilled and tapped the case for some brass break line elbows... Compression fitted some 1/4 inch break line to the elbows, after about 6 feet I got the bends right... Then another compression fitting to a 5/16 barbed fitting and some 5/16 hose... With alittle tweeking I was able to make a hose tie out of two mounts that hold break lines to a swing arm... Then I made the bash guard out of a master cylinder guard for the rear of a dirt bike... I still need to cut the headlight shell about 1/2 inch so it can be mounted... And I need to finish putting the bike together so I can start it and check for leaks.... Freaks
