Thread: Big Red 250 lighting issues.
    Feb 2007
    NS, Canada
    25
    Hi guys. I have an issue with a 250 Big Red, that I can't seem to get any help on. When I start it up and turn on the headlight, it only really works well on high beam, and this is only at idle. If I rev the bike, or drive it, the light gets substansially dimmer. I would have thought that it would work opposite of this. Makes for crappy riding at night.
    Any Ideas?
    Pennsylvannia
    1,147
    My dads '83 and '84 Big Red's do the same thing whenever he doesn't have a battery in them. Toss a battery in there and you'll have a bright headlight.
    Tionesta, PA
    5,747
    Or this might sound like a grounding issue to me. Check both battery terminals as well as your main ground.
    Feb 2007
    NS, Canada
    25
    Battery is good. Even when I put it on slow charge overnight and thow it in the bike it does this (Plus the batt is only 6 months old). Grounding issue could be a possibility.
    Jun 2006
    N.B Canada
    17
    battery is no good
