ok this might be a stupid question but i ordered a complete gasket kit for triz and there is no gasket for the main cases (crankshaft/tranny). there is supposed to be a gasket for that right?
theres also a little rubber oring where does that go?
when in doubt throttle it out
old ride 2002 GSXR 1000
new ride 1985 TRI-Z 250
.070 over - boysen reeds - head redone
2001 dodge ram "off road" (toy hauler)
bump bumpbump
most 2 strokes dont use a gasket on the main cases
id use some yama-bond
WWW.HREATV.COM
You need to use Yamabond/ semi drying liquid gasket on the center case of the gaskets, You can also use 1104 Liquid gasket, or Loctite Gasket eliminator....Need to coat all the surface's evenly and bolt it togther, Dont use too much as it makes a Big mess and You dont want pieces floating around in the bearings.
1985 Tri-Z-
Originally Posted by mywifeknowseverything
ok thanks guys
yea yamabond or 1104 works the best also permatex makes the same stuff for motorcycles and atv's that really good also!
the little o ring is for the oil filler cap..
thanks raffa
make sure the case mating surface is clean. also don't buy a cheap gasket sealer, or a no name sealer. you don't need a leak and have to pull the engine all apart and start all over!
Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
My Feedback
http://www.3wheelerworld.com/showthr...k-for-sblt500r
