Results 1 to 3 of 3
Thread: 85 R axle
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Missouri
    319
    85 R axle
    a 85 250r axle will go in a 86 250r but not the other way around rite?
    Jun 2003
    englishtown NJ
    2,676
    it will, with either you will have chain aligment problems. I had a 86 axle in a 85 carrier for awhile, I did notice that the axle ate up the left side seal. I would imgaine this would be similar the other way also.
    Sep 2003
    Elizabethtown PA
    1,581
    rustyhondas you have it exactly backwards. 86 axles will go into a 85
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
