Results 1 to 10 of 10
Thread: air compressor/sand blasting question
    bp739's Avatar
    bp739 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2006
    Southwest,Pa
    297
    I know there was a thread similar to this recently but I could'nt get the info I needed from it.
    Here's my question....I'm looking at a 26gal 150psi upright compressor...would this be big enough to use with a small pressurized sand blaster (5-20gal). It would just be for blasting frames and small parts.
    85' YAMAHA TRI-Z
    85'
    HONDA ATC 250R
    85' HONDA ATC 350X
    86' HONDA ATC 200X
    05' KAWASAKI KFX 700
    Jan 2005
    Jones, Michigan
    1,821
    easy answer
    just like i said int he last thread. Look at the sandblaster you want and see how many cfm or scfm it needs. then look at the air compressor and see how many cfm or scfm it is. If the air compresser meets the requirements of the sand blaster then your good to go.
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    bp739's Avatar
    Jul 2006
    Southwest,Pa
    297
    OK ,I get it now.....the blaster I was looking at requires 6 to 25 cfm depending on the nozzle size...so with a compresser that only runs out to 6 cfm I could only use the smallest nozzle . Thanks, now I understand...... 25cfm would be a pretty big compressor then....right?
    85' YAMAHA TRI-Z
    85'
    HONDA ATC 250R
    85' HONDA ATC 350X
    86' HONDA ATC 200X
    Jan 2005
    Jones, Michigan
    1,821
    Quote Originally Posted by bp739
    yupp 25cfm would be a BIG aircompressor. It atleast would have a big pump on it. i was just at menards and most of their big compressors only go up to like 12 cfm at 90psi. IM going to be buying a compressor soon so i can actually use half of my tools without the compressor running all day and whne i do i think im going to end up getting one around 12 cfm.
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    You can do small parts but a frame will be alot of work and cycles of the compressor.
    Worse thing with an undersized compressor is that when you first turn the blaster on it takes 10 seconds to get roaring, then it will maintain a good blast for about 30 seconds before it begins to decline in pressure and the cycle starts again.
    It will take a few minutes before it's up to 130PSI or so again. Each time this wastes alot of sand.
    Small parts with something to recover 75% of the sand is how I use my 6HP 30 gallon compressor.
    Pressure blasters are the bomb but need alot of air. Siphon blasters are more of a pain to use but lots more friendly to an undersized air compressor.
    scottyms's Avatar
    scottyms is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2006
    hey, just my two cents, i'm not sure what you are using for sand/media. you cant buy the cheap silica send anymore around here all i can get is called Black Beauty, it works but cost almost 10 bucks for 50 lbs. i can get a frame done local in a day for 30 bucks. i havent used my preasur blaster in 2 years. your better off to invest in a blast cabinet for the small stuff and let someone else do the frame.
    scotty
    Jan 2005
    Jones, Michigan
    1,821
    [QUOTE=scottyms]it works but cost almost 10 bucks for 50 lbs.
    scotty[/QUOTE
    go price aluminum oxide or glass bead.....$20 for 25 lbs.
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    Oct 2006
    2,504
    I buy all purpose silica sand from Lowes and filter through a screen $3 for 50 lbs. Pressure pot works for me with a 25 gal 5.5. horse but I know I could always use more PSI.
    scottyms's Avatar
    Feb 2006
    [QUOTE=dizasterzrfun69]
    Quote Originally Posted by scottyms
    scotty[/QUOTE
    yea but in a cabinet you dont have to keep buying more. how many frames are you going to do versus smaller parts that will fit in a cabinet. just my opinion
    scotty
    Nov 2006
    southern oregon
    2,338
    Waiting for your air to build back up sucks. Buy the biggest compressor you can afford, you may have it a long time. My compressor is like 6 scfm and it took me about 2 weeks to do an hours worth of blasting on a qaud frame...
    2-stroke lover
