Results 1 to 9 of 9
Thread: Carb Problems, 86 200X
    Bender is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    Chippewa Falls WI.
    234
    When i start the trike its revs just about wide open. last time a rode it, it ran just fine. I let it sit for about 2 weeks before this happened. I really have no clue why it started to do this. It was really cold the 2 weeks i didnt ride it, one morning i think it got to 37 below! At first i thought the throttle was stuck but i took the air box off and i could see that the slide moved just fine. The idle screw doesnt change anything. I took the carb off and cleaned the jets. no change! I think the throttle slide may not be comming down all the way. How far from the bottem should it sit at idle? Any suggestions?
    86 ATC 350X
    86 ATC 200x (my P.O.S.)
    ATC 70 (first trike,7 years old)
    Email: Bender@bodybuilders.com
    Sep 2006
    Long Island NY
    41
    37 Below!Holy *Edited**Edited**Edited**Edited* i thought it was cold on L.I but thats nuts.I would check to make sure the cable isnt snagged on anything and routed properly.As for the opening of the slide at idle its very little give or take an 1/8inch.
    Jun 2004
    Chippewa Falls WI.
    234
    The cable is routed just fine and not hung up. i think a have more than an 1/8 inch gap.
    86 ATC 350X
    Nov 2006
    Tulare, California
    719
    The throttle slide should be almost shut. Your pilot jet/mixture screw takes care of your idle. As for WOT at idle, maybe a lean condition from somewhere. Maybe you are sucking in lots of air. Other then that, check your carb and see that you have a needle jet that guides your needle into your carb when it opens. I know here with my 350x carb, the needle hung up at WOT. I took it apart and there was no needle jet to guide the needle back into the bowl. Now there is and its fine. Check that your needle is not bent at all. If its there and everything is cool, I would worry about your throttle cable.
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
    Jun 2004
    Chippewa Falls WI.
    234
    The needle is fine. The slide sits about a quarter inch up from completly closed, maybe more. I think this is my problem. How does this happen when nothing is different than before? Why isnt it sitting down like it should? Its like the cable got shorter overnight!
    86 ATC 350X
    Sep 2006
    Long Island NY
    41
    If the slide is sticking open that much its most likely your problem.Check the free play at the throttle if its tight it could be pulling the slide up when you turn the bars my klt does it all the time.
    Pa.'s Highest City
    8,058
    something else to check...
    Be sure to also check around the intake for an air leak.
    Yep, my intake looks like the grand canyon. Just push on it either way and it has a bunch of cracks, Good luck finding a new one!!!!!!! If you do, share the source!!!!!
    Jun 2004
    Chippewa Falls WI.
    234
    My cable isnt tight and its routed the same as it was before. There is no difference when I turn the bars. I will check for leaks though.
    86 ATC 350X
