Thread: 350x valve adjustment help please
    p26575r16's Avatar
    p26575r16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Reno NV
    252
    I have just fired up the x for the first time since the rebuild and the valve train seems to be out of adjustment a little, it does not kick over very hard (I have no decompression cable) and it should I have a 12.5:1 pison in it. The head was just rebuilt and I know the valves do seat properly. I adjusted all the valves to exactly .08mm (.003in) like the manual states, and trust me I have a touch of ocd so I checked it many many times. I was wandering what you guys are adjusting your 350x's to. My engine has a wiseco 12.5:1 piston in it, other than that it is stock. Thanks
    '86 350x
    '05 sportsman 500 (the couch)
    Fresno Ca
    2,695
    i leave mine way loose, compared to stock specs. more compression and a higher reving engine. if i rember right it was abuot double what the stock specs where.
    p26575r16's Avatar
    Nov 2006
    Reno NV
    252
    I'll give that a shot. Thanks
    '86 350x
    PA
    3,515
    my aftermarket cam is spected for .004 intake .006 ex
    WWW.HREATV.COM
    Columbiaville, MI.
    1,508
    Sounds like an issue to me , NOS and Swingin are correct as far as the clearance as far as what your cam is.. Now something I did on a rush job for my brother was ,when I laid the rocker box on the head and tightened her down i had the decompression lever in the up rite position and with a new 10.5:1 ,thus leaving the exhaust valve open,I could bench /kick it over by hand .. something too look at -make sure the decompression lever is in correctly,you should almost be able to stand on the kicker and not move it with that piston set-up.Did you back off the rockers and check it with nothing on them??
    MDR Racing
    LONG LIVE SANCHEZ RACING
    p26575r16's Avatar
    Nov 2006
    Reno NV
    252
    Quote Originally Posted by sandpuppi101
    I am certain that the decompression lever is in the correct position, However I will try to back off the rockers and try to kick it over to see what I've got. Thank you.
    '86 350x
