Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: 200x HARD To Start
    Howdy's Avatar
    Celina, Ohio
    10,079
    What could possibly be the problem is completely over looked here. How good of spark do you have? I had a 200x that ran great once it was running but didn't want to start. It looked like it was getting good spark but I checked the stator any way. I found the Exciter coil to only read 175 ohms it says in the book that that was good.
    But I changed the exciter out anyway. After that it started within 3 kicks everytime.
    To check the exciter coil you need a ohm meter. Take and unplug and check the black with red striped wire coming from the stator ( bottom end ). My rule is 215-240 ohms for the best starting ( on 200x's ). The lower the ohm reading the harder the machine will be to start. Lower = weaker spark.
    I only ever seen one check over 240 ohms. That machine ran fine also.
    Howdy
    jdparsons1's Avatar
    jdparsons1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Toledo, OH
    360
    I think im getting closer to a fix. It seems to me like it is flooding to easy. I went out this morning after letting it sit overnight and it took 4 kicks. The previoius owner said they never choked it so i followed their advice and did not put the choke on and it worked. If I put the choke on it is giving it more gas and less air and maybe flooding out quickly. Does this sound like a possibility, would it be something like the float level?
    Thanks,
    Jeremy
