Results 1 to 14 of 14
Thread: Kick and electric start just spins?????
    Jun 2006
    Niagara+SouthRiver ONT.
    132
    Hello
    Well big red has no kick start, with a bad one way clutch.
    But the electric start was still working good.
    Now the electric start just spins too.
    I turned the started gear by hand and the flywheel just turns freely
    What would be the cause of this? What part am I after?
    Thanks for any replys....
    85 Honda Big Red 250 es
    85 BMW 318
    67 Chevy C10 383 M21
    Howdy's Avatar
    Celina, Ohio
    10,079
    If the one-way clutch is bad, then there is a good chance you have trashed your starter and 1st reduction gear. Pull the little cover off and inspect the starter splines and the reduction gear. The cover only has 4 bolts holding it on, so it's a easy check.
    If you do a search of the 3WW forums you will find many postings about what causes this.
    Howdy
    Jun 2006
    132
    Yep I inspected all the starter gears first and they are good. They turn the flywheel freely.
    search reveals minimum rez.
    Jun 2006
    132
    kick start is blaaaaa *Edited**Edited**Edited**Edited* that is my shin
    and the electric is just a spin. Starter gears and flywheel turn free. Nothing else.
    Any ideas?
    florida
    2,328
    that means both one way clutch sprags are shot.....expensive fix.....worse if u wait! it will cost around 200 dollars to fix give or take a little
    florida
    2,328
    if u need help im building a 200S and a bigred right now im open for all questions
    There is another one way clutch in the flywheel mechanism - have you checked it?. I imagine it allows the starter to drive in one direction and free wheel in the other. ATC starters don't drive out like an aoutomobile. They are always meshed but the one way clutch keeps the drive going in one way only.
    florida
    2,328
    yea thats what i meant by 2 sprags.
    Jun 2006
    132
    I didn't know each one had it's own one way.
    I will check it out. I have the original moter all apart on the bench so I can look at that one and find whats busted. I found the one way clutch which works on the other motor. Turns one way
    Which one works with the kickstart and where to find the other one.
    Jun 2006
    132
    Do you think I should pull the motor to do this fix? Do I have to split the block?
    Jan 2005
    Jones, Michigan
    1,821
    well the one way clutch by the clutch assembly is 71.62 at servicehonda
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    florida
    2,328
    the one by thw clutch is for kick start and the one under the flywheel is for E-start
    Jun 2006
    132
    Quote Originally Posted by team-red-rider
    sweet
    85 BMW 318
    Columbiaville, MI.
    1,508
    Did you check too see if the woodruff key got stripped out on the crank!! Been there before!!
    MDR Racing
    LONG LIVE SANCHEZ RACING
