Thread: wider 200x axle
    East Peoria IL
    99
    wider 200x axle
    i've heard that 81-82 250r axles are swappable with 83-85 200x's and you just need to use the 250r sprocket/hub. are they any wider than the 200x?
    i know durablue makes an aftermarket +4 and that it comes with a sprocket hub, you just need an 81-82 250r sprocket for it, but that one is almost 500 dollars!
    any ideas on making my rear end wider without using spacers.
    USA PENNSYLVANIA
    102
    400ex hubs will add like 1 inch each side.offset rims would also help.
    East Peoria IL
    99
    Quote Originally Posted by PWK39
    yeah i had heard that 400ex, 300ex, and 250x hubs will work. i was going to buy some cheap 300ex ones on ebay, but someone beat me to it.
    what about 450r hubs though? i found a few sets of cheap 450r hubs that look like they'd add some good width. will they fit on the 200x and still use the same 4/110 pattern?
    Quote Originally Posted by SET THE STAGE
    I believe the splines are the same, definatley the same bolt pattern on the lugs. 450R hubs are brand new for 30$ each at Honda.....
