Results 1 to 11 of 11
Thread: Changing fork springs.....difficult?
    Sep 2006
    Michigan
    47
    Hey guys, just wondering what is involved in swaping out fork springs on an 85 Tri-Z? Is it difficult or pretty simple?
    1985 black & red Tri-Z
    2003 black & yellow Banshee
    Columbia
    5,131
    Very simple. Your going to change the oil too right? How about the seals, do they leak?
    You dont even have to take them off the bike. Jack it up so there is no preasure on the forks, remove the caps, and pull the two springs out (two in each). If you want to change the oil in them, there is an allen key on the bottom you can remove, and the oil will come out.
    Put your new springs in, measure out the correct amount of oil, and cap it off. The manual stats there should be 7 psi in the forks (if my mind serves me correct) that you can just fill with air. I have been told not to preasurize them, just to cap them off.
    I have been looking into some progressive springs for my Z, is that what your doing? Whats going in there?
    Good luck.
    Sep 2006
    Michigan
    47
    Thanks, Eric. Yes, I was thinking Progressive Springs also. Dennis Kirk has them for $75 a pair.
    East Peoria IL
    99
    i'm glad you posted this (both of you). i've been thinking of doing a little rebuild on my 200x. they seem to be leaking and the forks seem somewhat weak.
    Columbia
    5,131
    Quote Originally Posted by SET THE STAGE
    Rebuilding is a little more of a difficult process. Do you have a manual? If not I say you pick one up. You can download one from a link on here.
    Once you have done it once though, its a little more simple.
    the allen bolt on the bottom is not for draining it's for removeing the tubes, the bolt on the rear of the fork is for draining, I do think its a 8mm
    Columbia
    5,131
    Quote Originally Posted by bryan raffa
    Good call Bryan, thanks!
    Phoenix, AZ.
    6,719
    You can find the springs on ebay for like fifty bucks but you need to know the part number.
    InPiEcEs's Avatar
    InPiEcEs is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2004
    Northeast Wisconsin
    378
    the Progressive springs are a one piece deal right?
    I got em in my R, and those are one piece, for 85 and 86.
    One piece at a time. Status: The Beast is Done..06-23-07
    Back in the saddle again
    Currently owned rides:
    My sleds, and.........
    1995 CBR600F3
    1976 Kaw 400 triple-smoker......SOLD
    1986 250R...owned since 1990
    06-23-07........the R is finally done!!!
    ESR pipe, Aktive reeds/CR cage, 38mm PWK, +4 Dominator
    mild clean-up porting, an open K&N, CR and YZ calipers.......among other things
    Sep 2006
    Michigan
    47
    Quote Originally Posted by InPiEcEs
    The pics of them that I have seen show that they are 1 piece.
    Rittman, Ohio
    6,276
    They are one piece, but they use a different part for 85 and 86 TriZ. These are basically universal based on fork diameter, with PVC spacers to accomodate length differences between models.
    The drain plug on a TriZ is on the rear of the lower leg near the bottom, and has a 10mm head.
