Results 1 to 11 of 11
Thread: 225dx fork oil capacity?
    Apr 2003
    63
    i dont have a manual yet and my seals are coming in soon so i need to buy some fork oil. i dont know how much it takes tho, maybe some of the yamaha owners in here can help??
    Mine: 1985 yamaha 225dr
    partly mine: 1982 185s, 1984 200es big red
    Nov 2002
    1,189
    yeah, check your dealer. mine wasn't able to , so i put a little bit over oil in it, and let it seep out if it was too much. was a little bit messy tho.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Apr 2003
    63
    i did check the local atv shop and they said they didnt have books that went back that far, so i need to know from someone w/ a manual or somthing
    Southern MN
    1,875
    have repair manual
    I have the repair manual, but It dosent really show how much to put in. I think it said something about filling the fork leg to the top. It says to compress the spring, then pour it in, because that is supposed to soak between, and get all of the inside. Be sure both legs have the same amount of oil in them. After that, you grease the top, and put it back on. I'll take another look at it. Maybe I missed something.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Nov 2002
    1,189
    legs as in forks? grease the top? the oil does that job....am i missing somethin?
    My Rides
    Yamaha 200E
    Apr 2003
    63
    wouldnt it work just as well if i filled it up w/ the bottom hole plugged up and the spring out and then assembled it w/ the oil already in it? i dont have a press to keep the spring compressed. or could i just wait for the oil to soak through the holes in the piston?
    Nov 2002
    1,189
    fill it upsidedown so that the piston fills quicker, then reasemble. would be easier to do on a 225 that to take it all apart.
    My Rides
    Yamaha 200E
    Nov 2001
    136
    fork capacity is exactly 4 fl. ozs.
    '85 225DR...'85 200E Yamahauler...'83 YT125(complete engine rebuild)...'82 & '81YT125 for parts...'80ATC110
    Nov 2002
    1,189
    thanks, ill save that for future reference.
    My Rides
    Yamaha 200E
    Apr 2003
    63
    are you sure about 4 oz? i put about 8 in before the top part of the forks filled up and it still seems like it might be low cause theyre not very smooth-it seems like they are sucking air sometimes. i could only do the left one, when i tried to undo the bottom bolt of the right one the spring would rotate in the housing instead of the bolt coming undone. that side has never leaked tho so i think im going to leave it as it is until it starts to go bad.
    Nov 2001
    136
    Both of my manuals say the same thing. 4 ozs.
