Thread: 350x axle bearing replacement/removal
    Back in Happy Valley
    833
    Hey guys among other things i'd like to replace the axle bearings in the rear end of my 350x i just picked up, i was wondering if i will need special tools to take it apart and get the axles off. Any input from past experience would be greatly appreciated so i can get the tools i need before i start the job. Thanks in advance, TC...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    kb200x's Avatar
    kb200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    KY
    295
    Welcome to the Board! You won't need any special tools. The large nuts on the axle are reverse threads. You may need to heat the bearings to get them out? Do a seach this is a common question. Get a hold of a service manual and you will be all set.
    Good luck.
    86 350x "O' Smokey"
    83 200 auto X
    84 200x
    85 110
    82 70
    833
    thanks
    Thanks for the info i was hoping i wouldn't need any special tools. I got the manual on CD with the machine so i'll check that out, if i need to heat or press the bearings out i can do that at the machine shop i work at. Is there anything tricky to getting the shaft out of the housing? I've been browsing the board for a while and finally decided to join now that i got the X and plan to start making it a better than average bike but i still plan to ride it all the time...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    Nov 2005
    New Jersey
    659
    Nice ride, good luck with it/them!
    833
    Thanks again, last year i bought the R and a very clean 200x but i'm 6'2" and the 200 was a little small for a long ride so i decided a 350 was right up my alley. I love the R too but i really dont ride it much due to the higher maintenance that is required, i hope the X is a fire up and ride kind of machine like my 200 was...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
