Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: ytm 200n i need help
    traxxasx's Avatar
    traxxasx is offline Alligator sized brain can't spell you correctly. Arm chair racerRoostin Away
    Sep 2005
    las vegas
    1,184
    Quote Originally Posted by a3dudek
    ok i got my ytm running way better. it actually moves now. it is still puffing a ton of smoke out though, it is white smoke. i am not sure how to fix it i think it might be the mixture but i dont know where it should be. thanks alot
    If its puffing it out like alot, then go tbuy a compression gauge and check compreesion. White smoke is burning oil, which probably means new rings.
    Id have mine running rich and it couldent smoke it if wanted to so thats hwy im saying rings.
    MY FEEDBACK---
    http://www.pbnation.com/showthread.p...2#post20992142
    +6 positive feedback.
    WaLLa BinG WaLLa BoOm ShE's DoNe!!!
    MY 225 Dx
    Piped, jetted, 2 stage uni, wheel spacers.
    __________________________________
    My 82 250R
    All original even with tool kit.
    Stage 2 uni, no air box jetted.
    Pa.'s Highest City
    8,058
    Yup, that's what I would recommend to do next. check the compression. Did you clean the carb out good?
    I always thought the 200 was a four stroke? You aren't mixing oil with the gas are you? I'm not much of a yami guy but I'll try and help you as much as I can (check your pm's)
    I'm just not sure what you meant by the mixture? Did you count the number of turns the airscrew was when you took it out of the carb to clean it? Is the clip in the same position on the needle inside the slide?
    We need a bit more info on what exactly you did to make it run better
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    Change the oil too, and check the muffler for foreign objects that may burn or smoke.(mice/squirrel nests)
    1985 Ytm 225 dr (Black and gold)
    1984 Kxt 250 A1 Tecate
    1981 KLT200a1
    1983 Yt 175
    1985 Atc 350x
    1983 Klt 200 C
    1985Ytz250 Tri z
    Feb 2007
    Edwards Co
    49
    no iam not mixing oil with the gas, i was talking about the gas air mixture, i idn't know if that would have anything to do with it. yeah i didn't mess with the needle setting it is still in the middle, what would a different setting do ?. before i cleaned the carb really good which made it run better i was messing with the air screw to try to get it not to bog and i don't really know where it should be now. do you know how i can calibrate it. i have also put fresh gas and oil in it
    thanks again
    Pa.'s Highest City
    8,058
    download the manual here if you don't have one. All the info you need should be in there.
    http://www.drivehq.com/file/ShowFold...shareID=233462
    Be sure to thank ! for hosting those manuals for us.
    traxxasx's Avatar
    Sep 2005
    las vegas
    1,184
    Quote Originally Posted by atckowalski
    I would check that out to, since ive already seen a 250r not run because the exhaust had somthing dead animal in it.
    MY FEEDBACK---
    MY 225 Dx
    My 82 250R
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    check your oil level in your machine I bought 1 last fall ytm200e that smoked while running and it was totally full of oil I drained over a quart of extra oil out of it. if it still smokes it needs rings
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    Feb 2007
    Edwards Co
    49
    does anybody know the air screw settings for the tym 200n and the settings for the pin in the carb . the manuel website is not working for what reason i don't know. if anybody can get the manuel for my trike i would greatly appreciate it
    thanks again for all the help
    Pa.'s Highest City
    8,058
    Hmm.. that site worked for me just fine a few days ago. try this.
    http://www.drivehq.com/file/ShowFile...208:44:47%20PM
    lokisbuddy's Avatar
    lokisbuddy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    michigan, oscoda
    429
    hey i know you probly already checked this but if the choke isnt open all the way for somee reason it will also do that (it happened to my 450f
    Feb 2007
    Edwards Co
    49
    does anybody have the manual for a 1985 ytm 200n. this website that was posted is not working for me. i have tried multiple times and can;t get it to work.
    Pa.'s Highest City
    8,058
    It does indeed work so it must be something with your computer. do you have that adobe reader program? that is what you'll need to view the thing once it's downloaded. other than that all I can tell you is to buy a clymer's manual if noone else can help.
    Sep 2005
    central Illinois
    651
    when i first got mine, it would run fine till it got warm and then spew white smoke. Turned out the previous owner had carb problems and the crankcase was full of gas mixed in with the oil, proly not the case but worth a check
