Results 1 to 9 of 9
Thread: pipe ????s
    Feb 2007
    flordia
    34
    pipe ????s
    ok i just got my new pt hi rev pipe for duncan racing in today. and i didnt get the chrome done because i like the look of the welds and discoloration of the metal. but in need to keep it from rusting.so i was thinking of putting oil on it. but not sure what wait oil to use. would 20/50 last longer then 10/40. also does any one know of any thing that works any better or makes it change colors faster.
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    Any oil or whatever you put on there will burn off pretty quick as soon as the pipe comes up to temp. It might even leave a stain that you can't remove very easily. What you have to do is...after riding...EVERY time after you ride...clean your bike,dry your bike and pipe..and then spray the pipe down with WD40 or LPS 1 and rub it with a fine Scotch Brite pad. *The pipe will NEVER look as good as it did when you took it out of the box*. It's a lot of maintenance to keep a bare pipe looking good.
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    Pennsylvannia
    1,147
    Maybe you could use some high-temp clear coat on it? I would assume that would work pretty well. I'm not 100% sure, but I would assume so?
    Feb 2007
    flordia
    34
    i didnt know any one made a hi temp clear do u know where i can get some
    Apr 2006
    Crestview, Florida
    2,429
    Check with a truck stop and get the polish they use on the big-rig pipes. Any oil or lubricant you use will burn off after a few minutes and smoke like crazy, not to mention stink.
    Oregon
    2,471
    did you figure out the jetting on it ?
    Jun 2004
    Oregon
    1,783
    I got mine right out of the box as well, I cleaned it after every ride and then some..And last i always sprayed with wd40..Well It took 3 years but it turned into a complete rust bucket..Now i have to get it ceramic coated! All of my non chrome hr have rusted up on me..I guess its because i live in oregon Good luck man! I would of gone with the chrome
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Feb 2007
    flordia
    34
    mabby ill hi temp paint it.
    Feb 2007
    flordia
    34
    i just got the pipe on. i cut my hand pritty bad when i make a fist my nuckel pops out of my hand.so i am still working on geting new reeds and carb on.then ill get it jeted when my hand gets better scince its my clutch hand.
