Results 1 to 15 of 28
Thread: Red Kote, Kreem - gas tank liner suggestions
    Jan 2005
    Slatington PA
    4,372
    There are a few things I learned when using these products so I thought I'd pass it on (may not be in exact order) ..........
    if you muratic acid your tank (I used a 50/50% MA/water solution), have a nice large tub to catch the last remainder of it that you must shake out of the fill hole, I have never found to get it all out by the petcock hole alone
    with Red Kote there is no need to MA the tank (Kreem there is), but I did mine anyway
    the tank may spring pin hole leaks from removing the rust so tape them up before doing the liner. The liner seals up to a 1/16" hole I think they said. You can also patch them with a few products made to do so from auto part stores .
    make sure you have the set up figured out as to how you are going to prop the tank once you drained the liquid liner out (some tanks do not naturally sit how you would want them to because of the shape or petcock location)
    when draining, have a good flashlight so you can watch the flow of it so you know which way you still must tilt tank for best flow out of the petcock hole.
    depending on the tank, it is really hard to not get minor puddles out, which are a no-no. I had two very minor ones so I left the tank dry 2 days before applying the second coat. I think in 12 hours it was totally dry but I wanted to make sure that the slight puddles (very slight) had full chance to cure as much as possible
    the baffel in picture certainly makes it a bit tougher for draining. it was a real pain actually
    this is my 1st tank with red kote (did three with kreem through the years) and I really don't find it to flow any better then the kreem. I thin both products out with acetone which they do say you can do so
    have some Q-Tips to clean out the petcock hole so the liner stays as thin as possible. If your doing two coats, it's best to use a wire brush and clean it out so there is none on so second coat flows out as good as 1st
    the lip in the fill hole will usually not get an even coat and it's best to tape off the fill hole rather then use the cap itself, I used the cap and it looks like crap now, so I'll wire wheel it all off and just give it an even dunking of the stuff so it will look uniform
    Attached Thumbnails Attached Thumbnails DSC03898.JPG   Red Kote - Tank petcock baffle.jpg
    Oregon
    2,471
    Nice info , Where did you get a small wire brush to fit in the fuel lines ?
    Will be doing this soon
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by ceaserthethird
    In the plumbing section of most hardware stores, I used the smaller one here.
    About 2 bucks a piece or so ............
    Don't freak if you get some runs that come to a halt and don't flow good, this always seems to happen to me, it's very hard to get an even coat thru the whole tank and I had mine thinned!
    It was fine till I thought I'll try and get that last small puddle out by tilting the tank and then the product just flowed a bit and came to a sudden stop but I'm sure it will hold up fine. Just glad you don't see it cause it does bother me that it did not get real even like on other tanks I did with Kreem.
    Kreem was not perfect either but seemed a bit easier to work with then the RK stuff
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    I did my 200X Tank with Kreem.Came out good.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by edog
    Some really hate the Kreem, I think Howdy was one who had troubles with it.
    I like the creamy color of it more then the Red Kote
    That's right, I still have my 85 Honda 700S Nighthawk and that got a kreem job a few years ago, I think I'll just go pop the fuel cap and see how it's doing!
    Looks perfect yet!!
    OH MY GOD Your RIDING your machine on your avatar pic !!
    Newfoundland
    5,280
    Whats the cost of Red Cote verus Kreem? I need to do this with a plastic tank sometime the spring.
    Jan 2005
    Slatington PA
    4,372
    They are both in the $30 range but won't work on pastic tanks.
    I must say though, it certainly sticks and coats my plastic funnels just fine. Some say it may work, I'm telling you what the manufacturer says.
    Newfoundland
    5,280
    It will work on plastic tanks. I've heard of people doing it on this site.
    Edog...why do you post when you have nothing to say or add?
    I need to coat the plastic tank, it keeps paint on plastic tanks from bubbling as well as stickers.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by BigGreenMachine
    Yea, it might be holding up now but for how many years ? How long ago did they do it? If it was just a year ago or so that isn't saying very much as to how it will hold up in the long run.
    The manufacter should know better then anyone if it will hold up and I would go by what they say but that is just my suggestion, you wreck what you want!
    Here is a segment of the RK directions ..........
    We are told that two of these thin coats still take less time to dry than one thick coat.
    Red-Kote ® does not stick well to plastic tanks or to plastic parts inside a gas tank.
    Do not coat over other coatings. Remove old coatings completely first, using M.E.K. or other solvent. Call us if you have a problem.
    Do Not Use in Dry Sump Oil Tanks, oil temps can easily exceed the 250* max temp of this product and cause serious damage to oiling system and or engine causing engine failure.
    Will not stick to Plastic Cells
    He said he used Kreem on his 200X and it worked good... That does add some usefull information.
    Usually EDOG posts his desire for pictures which agreed, is a waste of a post.
    BUT, thats just him and at least he can spell and does offer other helpfull information at times.
    Maybe he rides his ATC's or maybe he just shines them up - yet another debate.... But he sure loves restoring trikes and giving them away for cheap money compared to the time and money he spends so he's AOK in my book And someday were gonna get a ride together and post all the pics
    Newfoundland
    5,280
    Dirtcrasher, there was a reply after Huffa's reply to me. It was edog and his exact post was;
    Plastic tank?
    Was in a bad mood and that struck me as very stupid...added nothing and made it sound like I didn't know what I was talking about.
    ANYWAYS!!! I want to paint my tank and put some decals on then clear it all so it lasts. I was told by Greenlightning on this board (owns the orange/checkered T3) that you need to Kreem or Kote the tank first so you don't get bubbling.
    Nov 2007
    Texas
    48
    What do you use to remove old Creem liners that are peeling up?
    1981 250R
    1985 200X
    1992 Lark Trike!
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Tres Amigo View Post
    Acetone. Just keep swishing it around, empty, do again till it's gone.
    That's how I did it anyway.
    Jul 2006
    hmmmm..... thanx for that info.... I got 3 tanks that need that done.
    Jan 2005
    Slatington PA
    4,372
    I noticed in my above posts that kreem directions said for removing to....... " Remove old coatings completely first, using M.E.K. or other solvent."
    I have no idea what M.E.K. is but just thought I'd point this out also.
