Thanks Huffa!
Thanks Huffa!
1981 250R
1985 200X
1992 Lark Trike!
I just peeled mine out with a screwdriver and prybar.
Then found the tank also had several 1/4 to 1/2 in. rust holes in the bottom. I welded in a patch, but then started finding several pin holes all over the lower right side of the tank. After about 3 hrs, I gave up. time for another tank.
one of the companies make a kit specifically for re-doing a liner. It comes with whatever needed to remove the old liner. The easiest way to remove the liner is to not put one in it.
I hear you can coat the plastic tanks too. MEK should open the plastic up to allow for adheision ??
quiet people seem intelligent
Huffa, that is a disclaimer. Companies do that for various reasons - sometimes just because a lack of knowledge. Have you coated a plastic tank and witnesseth what you speak of?
I really can't speak because I have not tried it either. I have a BW80 tank I suppose I could sacrifice for the sake of our evolution!!
http://www.caswellplating.com/aids/epoxygas.htm A quick look turned up this product - I have not tired this either - but note the "applications" section at the top right of the page.
thanks John..... looks like the BW80 tank is up for sale!!!!
If I referred specifically to "kreem" sorry, I dont like it on metal; nonetheless plastic.
I am trying redkote for the first time soon - after that I will check out the caswell product.
BTW- I just read some info on POR 15 and they say to use their paint stripper product to remove old liners.. I know other companies make some stuff too just never had to deal with it. I think acetone would work jsut as well like you said...
http://www.por15.com/Data%20Sheets/f...aler%20pdf.pdf
In any case, the caswell product should be good on plastics
MEK is methyl ethyl ketone, a sweet-smelling powerful solvent usually used in aircraft maintenance shops. It's also a known carcinogen, which is why the military no longer uses it. I'll tell you this, if you're able to get some and use it, you'll want to from that point on. It's definitely the good stuff.![]()
Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
"To err is human, to err continuously is liberal." - Me
