Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: Bought my first 250r-YEAH BABY!!!!
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Just picked up my first 250r today, very happy!!
    I thought you already had it.
    Nov 2005
    New Jersey
    659
    Well, theres a little story behind it-was supposed to have had it-seller had promised to deliver it, but that didnt work out.So-I went to get it.
    First things first, it isnt a 86 it is an 85-the seller wasnt to updated on it????
    Second, he stated it runs great-went there didn't run at all.Tryed to kick it couple times, nothing.All of a sudden I smell fuel, look down and it is dripping from the pipe at a steady rate-seller tells me I'm gonna have to clean the carb and tank,he THINKS the fuel is bad and thats why it doesnt start-LOL.
    Overflow lines are pouring fuel, and plug is dripping wet-the term RUNS WELL isnt going to fly with me right now.I'm not happy
    Seller stated the rear bearings had been replaced and in "perfect shape" -again after quick check they are loose, they appear to have replaced but locking nut is hand tight, as is the rear hubs and aftermarket wheel extenders.
    Plastics were pictured by seller as OEM, get there they are Maiers front and rear, the tank which appeared to be in great shape in the pictures is very poor condition cosmecticly-thats not a big deal to me as the OEM plastics I believe are still available for this but nontheless I had pictured OEM and they arent.OK price is going to be as discussed/renegotiated thats for sure !!!
    Motor has been rebuilt, stock bore , compression checks out, it appears to have been recently done as the case gaskets, water pump and side cover gaskets are clean and fresh,and he provided paperwork from shop that did work, so we ok there hoefully.
    So-after a brief discussion he knocks off 500.00 and I take it home.Get it home immed try camera-dam fiance didnt charge the batteries, so pics gonna have wait till tomorrow-sorry fellas!! but I tear into it, put fresh plug and check for spark, got it.Move to the air box and carb, airbox has gas smell in it and residue of fuel, inlet to the airbox has fuel inside it, but a small amount-so I pull the carb, slide is worn allitle but no scrathes-tilt the carb to start on the bowl screws, fuel spewwing out from every angle, obviously we have bad needle seat or stuck float valve as the carb was totally filled up to the top of the needle, as was reed cage.Pull the bowl screws, totally flooded out, so I have apparantly found my problem,needs all new internals-I am relieved but not happy to say the least.I pulled the reed cage and it is fine, no light between the petals, they sealed good although I do not think the cage and reeds af aftermarket-like a V-force or Boyseen but I may be wrong-I'll take picture of them for you guys to help me there.
    Now I have question: what the stock carb for these machines?I have a PE on mine it has the markings on the side of it as follows: PE 37A A WF the internals are as follows:
    52 slow jet
    150 main jet
    D105 needle-clip on 2nd from top
    38 float valve
    26E-30 slide
    Are these stock for that carb and or is that carb stock to the machine by chance?Where do you guys like to purchase your carb parts from, I have used CARB PARTS WAREHOUSE for many Kiehin stuff in the past, but would love any imput to another supplier.Also, I am going to replace several items on the machine like the kickstarter, fuel tank, headlight bezel and air box lid-again is there a place the board like to give bis to by chance?Opps 1 other thing, the pipe is a Paul Turner but it has numerous dents in the expansion chamer by the front wheel and appears to have been fixed numerous times in the past, although I have no idea if in fact the jug is on the stock bore without ripping the top end off, any ideas on a pipe to buy,I do not wish to keep this one presently.Thanks for the help guys.
