Just got it.
Is this engine going to fit?
and more importantly is the front sprocket going to line up with my 200m back sprocket?
Thanks to anyone with input
Just got it.
1984 Honda ATC200M
1984 Honda ATC200ES
ive done this before,, if this is the high low range engine same as 83 big red yes it will work.... i had an 83 big red engine in my 200s and my 200x.. only trouble i had was i had to haul off the starter and plug the hole because it wouldnt fit wit the frame and all but if you are puttin a 200e engien into a 200m it should go right in no trouble and with your starter attached, so i say GO FOR ITT !!hope this helps ya...o and for the front sprocket lining up with the back one, it wont give ya any trouble at all.. but make sure your chain is tight cuz if your chain gets caught up around the front sprocket u wont be to pleased
