Results 1 to 13 of 13
Thread: 380r big bore
    Aug 2006
    NW Ohio
    1,043
    380r big bore
    well im going to be picking up a 1986 250r here in a couple weeks and i no they are fast.... but i live for speed and i was looking at the ESR web site and seen the 380 big bore well my question has anyone used this yet? is it reliable? how was the over all performance? would i be better off to spend the almost $1600 on a cr500 conversion? well thanks in advanced!!!
    Pennsylvannia
    1,147
    Uhm.. 380? That would be a complete waste of money because you would never be able to use all of that power. Not to mention you'd have to buy a real long swinger and a new chain as well as get the cases machined. You would probably be going through clutches faster than you can drink a glass of water. I'd personally just get a 310 kit.. I'm sure they have more than enough power to quench your need for speed.
    Jan 2005
    Slatington PA
    4,372
    I'm not a power junky by any means but I'd go with the 500 for sure, I just think it would be more reliable.
    Pennsylvannia
    1,147
    Yup. If you absolutely need that much power, go with the 500 conversion. The engine has a larger displacement, and all of the engine components are made to withstand the power of the engine.
    But I still say that 310cc would quench your thirst just fine.
    Aug 2006
    NW Ohio
    1,043
    i live in northwest ohio its all flat land so yeah staright lines and some trail riding is what i do thats why i was thinkin the big block big bore kit would be easier than a 500 conversion since its a bolt on kit you know.
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Have you spent much time on a 250R? Get it dialed in with stock components and then do a ported stock jug before you move onto the 380 kit. You'd be suprised just how fast properly modified stock parts are.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Smile
    Quote Originally Posted by Billy Golightly
    Very good advice
    My 85 had head work done to it.It hall ass
    Aug 2006
    NW Ohio
    1,043
    yeah my first ride was a 200s then a blaster then a banshee and supposedly banshees are just as fast or faster ive rode a 250r yes they do hall i was impressed but i thought it needed more power... i live for speed... go all out or not at all!!
    Jun 2003
    englishtown NJ
    2,676
    I don't see a need to go that big, the 310 on my bikes is scary fast. I rode my 310pv with the stock swinger, it was impossible to keep the front wheel on the ground, with a +1 it wasn't bad. I agree, you will be suprised how fast a well modded 250r is. Replacing the bearings, rebuilding the suspension, good tires and with a wider axle, you will be very suprised how fast and well they handle. Be aware, that you might need longer swingarm with a motor like that and when you put them on, the costs add up quick, since you need to revalve your shock.
    viper's Avatar
    viper is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2007
    milan missouri
    215
    i have never ridder a 500 conversion but have rode the big ESR pro-x cylinders and unless you arent planning doing anything but drag race the bike it would be a serrious mistake to put a 380 in it .....i rode a esr 370 at the duners that had a +12 arm and it would scare the *Edited**Edited**Edited**Edited* out of you when ever you would gas on it ...was just brutal !!!!!!! but its your monney so do what you want just my .02
    350 stock cyl drag banshee
    85 yamaha tri-z stretched and powered by a SPROCK RACING big bore on alky baby ..yes its fast and no you cant ride it ...lol
    86 atc 250r
    86 350x
    ????? who knows what else ?????
    and if you want to take donations i will stay home !!!!
    Anaheim
    1,270
    i really want, or wanted to do a 500 conversion, but the amount of modification, and time that mus tbe spent to pull it off... i dont think is worth it in the end... (personal opinion). a 370R or 380R are frakin fast... faster then you need to go lol... IAm a speed freak, i love to tweak stuff and get more power... IF i was going to go big bore, (already own a pro-x 310 pushin plenty of ponies) i would build a 350... a 370 or higher... will only provail in the torque output in my honest opinion... i have seen drag 350's run against 370's and the holeshot gets the win.... get a 310 dial it in and see if you need to go any faster...
    GPS 83.4MPH top speed
    Adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Phoenix, AZ.
    6,719
    Quote Originally Posted by 200x newby
    You just happen to live near one of the better 250R tuners in the country. Take your stock jug to PR Racing in Toledo and ask for the nationals port job. With that port job, a good pipe, reed cage, K&N air filter with no lid and a 38 or 39mm carb you might not feel any need for an expensive top end or motor swap. It will absolutely crush a stock 250R and many, many highly modified ones as well. Guaranteed. Throw a heavy duty clutch in there too (trust me, you'll need it after all that).
    illinois
    743
    you could buy my 93 cr 500- way too much to list- then part it out after you get what you needed
