Results 1 to 15 of 22
Thread: Best way to remove engine casing gasket?
    Jan 2005
    Slatington PA
    4,372
    I usually use a razor blade, is there an easier way? This gasket is really on good.
    Kansas City
    3
    removing the stubborn gasket
    Take a rag soak it in lacquer thinner and lay it on the gastet to loosen the adhesion ( make sure you keep the rag wet with lacquer thinner) and then scrape away.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    "Fine" wire wheel.
    the best and easyest! is this a must in the tool box!
    http://www.jackxchange.com/products/IR301-2MK.cfm
    it dont get any easeyer than that!
    hey, minimoto tool, with a mini wire brush.
    one cylinder is not enough!!
    That sidecase is like an SX with the starter and can be a bear to get every nook and cranny. I like to use a wood chisel that I sharpen on a disc sander. It has the reach to get in there, if you see any aluminum coming off your using too steep of an angle. The gasket remover spray also works very well but should be brushed on as the overspray eats paint.
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Carefull getting that stuff on the inside case and leaving it there.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Dirtcrasher
    Lot's of good ideas here, thanks guys!
    DC, you say spray, then "brushed on", does it come either way? Can I get the stuff at almost any auto parts store?
    Any particular brand?
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by edog
    "Fine" wire wheel.
    Is that what you always use edog? I think I have a fine wire wheel.
    Can you show me your fine one, I want to compare.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by 4cylinders
    A dremmel tool you mean? I have one of those.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Petenpole
    I'll try a small section, just to see how your method works.
    Lacquer thinner, paint thinner, it's all the same thing, right?
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by bryan raffa
    Is that what you have raffa man?
    Quote Originally Posted by Huffa
    I use the spray stuff but spray it on a piece of aluminum foil, then dip my acid brush into it.
    Any wire wheel does beat up the aluminun to some extent and I won't use them.
    When I'm done scraping, I use a stone with WD40 sprayed on it to make the gasket mating surfaces perfectly flat before I assemble them. I've never had a leak with this method. Lots of leaks when I was a stupid kid, thank god now I'm a stupid adult
    Jan 2005
    Slatington PA
    4,372
    When I'm done scraping, I use a stone with WD40 in it to make the gasket mating surfaces perfectly flat before I assemble them. I've never had a leak with this method. Lots of leaks when I was a stupid kid, thank god now I'm a stupid adult
    Me too at times!!
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Are you talking about the wire wheel?
