Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: Best way to remove engine casing gasket?
    Quote Originally Posted by edog
    Are you talking about the wire wheel?
    Why is he crazy? He wants to compare your wire wheel to something.
    Hell you love pictures better than everyone on this board so get on it
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I use either a gasket scraper or the same thing raffa posted. Well not the EXACT same thing but a 90 degree die grinder with one of those pads on it.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Dirtcrasher
    Yea, why is that so crazy edog? I want to see what you mean by FINE because I have a fine wire wheel and to me it's still too course to use on the casing.
    .......and like DC says, your a picture freak so I'd figure you would jump at the oppertunity to clickity-click!
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Billy Golightly
    Gasket scraper, that's a tool with about 3/4 to an inch wide blade with a screw driver type of handle on it, is that correct?
    Can you get them in all kinds of different widths?
    The raffa tool and your grinder sound great but it's not all that often I take motors apart. What other use do they have, if there are quite a few, that may make it more attractive to me for shelling out the money.
    I just don't to pay 70-80 bucks for a tool I might use twice or once a year, that's why the scraper seems more the hot set up for me.
    aquapunk's Avatar
    aquapunk is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2003
    borger, texas
    210
    i used a die grinder with a softer pad. came off of my 200x no problem. just dont push down too hard, im might wear a low spot in your case.
    Quote Originally Posted by Huffa
    Gasket scrapers are nice because they have a long thin handle and a short wide scraping piece. A regular wood chisel does the trick especially if you buy the gasket remover - I think the one I use is Permatex
    ya thats what i got huffa, you can get all kinds of pads for it. You can use it for sanding, removeing rust,removeing paint, polishing&buffing, shapeing fiberglass. you can also find them cheeper, I just used that pic for to show ya what it looked like.
